Is this possible?
Old Jul 11, 2006 | 02:19 AM
ON's Avatar
ON
Is this possible?
I was wondering if there was any way to wire the power to the head unit (any head unit, oem or aftermarket) so that when i start the car from the "on" position, the power won't shut off when i start the engine? Like when i get gas i leave the radio on, but when i finish and start the car up, the power cuts off and my head unit has to re-boot again.
Old Jul 11, 2006 | 05:46 PM
ON's Avatar
ON
Anyone know what i'm talking about?
Old Jul 11, 2006 | 05:53 PM
saitcho's Avatar
I doubt that its possible because you're switching from all battery power when key is on ACC to all alternator power when engine is running. This will happen no matter what you do. If you wired it to always run off the battery, your battery would die. You would probably need another battery to run it off during the switch, and even then there is going to be a noticeable interruption.
Not worth it.
Old Jul 11, 2006 | 07:12 PM
G35 Mass's Avatar
Just wire the ACC wire from the radio to the battery.
But that will allow you to leave the radio on with the key out...
Old Jul 12, 2006 | 01:32 AM
bconrey's Avatar
You might be able to try a remote start button, not sure if/how that would work since the key is chipped, but effectively you'd be using the button to start the car without turning the key any further than it is already at the 'ignition' setting.
You'd want a decent pushbutton switch and a helluva relay, and have a good understanding of what you're doing. Logic suggests that provided you tap into the starter circuit after the chip sensor, this might work, but do this at your own risk.
Oh and do this at your own risk. Good luck!
Brian
Old Jul 12, 2006 | 02:13 AM
MiloX's Avatar
To the OP:
I am interesting in knowing why you want to accomplish this. I have no suggestions to provide... sorry about that. Just curious.
Old Jul 12, 2006 | 02:25 AM
ON's Avatar
ON
well on my firebird, the radio would stay on when i start the car from the on position. i guess i kinda gotten used to that before i got my G. its kinda annoying to have that little interuption when i start my car. oh well...probably just a GM thing.
Old Jul 12, 2006 | 02:40 AM
badlittleboy007's Avatar
anything is possible.... I could be the next Asian president in US.
Old Jul 12, 2006 | 03:30 PM
ON's Avatar
ON
awesome! i'd vote for you man!
Old Jul 12, 2006 | 03:37 PM
KPierson's Avatar
All you have to do is switch the ACC lead on the radio to an IGN lead. There are three types of power feeds in a car:
1. 12vdc hot - 12vdc all the time
2. IGN - 12vdc in the on and crank position
3. ACC - 12vdc in the On position only
Keep in mind that the car was purposefully designed to act the way it does (cut power to non vital accessories during cranking). I doubt having just the radio on during cranking would cause any problems, but I wouldn't add much more of a load, especially if you live in a cold climate or don't drive the car very often.
Old Jul 12, 2006 | 03:46 PM
badbread's Avatar
Unless your running 1/0 guage to a massive 3000watt amp and a couple 15"s when you start your car...
Old Jul 12, 2006 | 04:29 PM
rob40wilson03's Avatar
if it was a GM thing, then maybe it didnt turn off because there was something wrong with it, haha
Old Jul 12, 2006 | 10:16 PM
ON's Avatar
ON
Thanks! i'll have to try that when i get the chance. I live in sunny ol southern california, so i'm not too worried about any below freezing temperature over here.
Old Jul 13, 2006 | 01:33 PM
badtziscool's Avatar
Given the massive current drain when you engage the starter motor, couldn't that in some way damage the radio or electronic equipment? Having voltage and amperage flucuate frequently?
Old Jul 13, 2006 | 07:16 PM
KPierson's Avatar
Typically OEM electronic devices have very stiff power suppplies on them that will enable them to survive the harsh electrical environment that a car provides. Several of the modules that KPtechnologies sell are connected to hot power and we've never seen a power supply damaged, and we use a very basic power system compared to what Nissan uses.
