Navi Help
Old Aug 3, 2006 | 07:42 PM
Floyds_racing's Avatar
Navi Help
I want to remove the stock DVD Rom does anyone know how hard it is to remove and does anyone know if the factory screen has normal RCA video jacks?
Thanks
T
Old Aug 5, 2006 | 10:02 PM
KPierson's Avatar
The stock DVD Rom is actually the stock navi system. Without the rom the navi system will not function at all.
The OEM screen is a RGB/S signal. You can get adapters to turn it in to a normal yellow video plug.
Old Aug 5, 2006 | 10:31 PM
G35maniacG35's Avatar
I use the TVandNavto go and an external DVD player.
Old Aug 6, 2006 | 07:38 AM
where do I get it and how much? or is it easier and cheaper to make own?
right now I dont care about the Navi and I dont have money for the finisher, bracket and A/C controls. I have a pioneer dvh-5000mp already and 2 sets Infinity Kappas 6.5 Comp for it from my last vech. I was just going to put the pioneer were the dvd-rom is.
How hard is it to pull out the DVD- ROM and the console area?
Old Aug 6, 2006 | 12:27 PM
RedG's Avatar
<--12 More Years
Get the Nav2Go unit. I have it, and it works great. You need a separate DVD player.
Old Aug 6, 2006 | 01:58 PM
footmasta's Avatar
Not to highjack this thread, but I was looking into getting that deck for my 04 g35. It looks like it wasn't meant to fit in that single din slot. Did you have to modify it to accept that deck? Is that how all single dins look on our cars?
Old Aug 6, 2006 | 06:41 PM
for the single di, you do not need a new bracket, and the player fit perfectly, but you do need to modify the bottom cubby hole, you are gonna need the the finisher cover for the double din, I dont know how it is on the 04 but on my 06 you are also going to need the AC controller and thats the expensive part.
Old Aug 6, 2006 | 07:52 PM
2004v35's Avatar
where can i get the dvd navi to go?
Old Aug 6, 2006 | 10:25 PM
emtguy05's Avatar
go to www.tvandnav2go.com and order it from there.
Old Aug 7, 2006 | 07:59 AM
OK OK you are way off here I just want to make my screen to work with a normal DVD palyer!
Old Aug 7, 2006 | 08:09 AM
amthar's Avatar
no no you are way off here. Both units that have been mentioned in this thread allow you to connect virtually any external video source (IE: a DVD player) to your stock screen. Very simple.
Old Aug 7, 2006 | 09:06 AM
I have a External DVD already!! I asked where to buy the harness I dont want the Navi and TV togo or whatever its called. For now Im keeping the stock Bose Headunit and removing the stock DVD-Rom and replacing it with the Pioneer DVH-5000MP headunit to use with the screen for movies and whatever all Bose speakers are being replaced with Infinity kappas and a JL sub and PPI amp I have all that covered just need to know where I get the harness or how to make one the convert the RGB to normal RCA!!
Old Aug 7, 2006 | 09:41 AM
amthar's Avatar
The TVandNav2Go is not a DVD player... it is the adapter you are looking for. That's all it is, an adapter. It's not a DVD player, it's not a navigation unit, it's not a TV tuner.... It has an RGB output plug on one side and an RCA composite video input on the other... actually I believe it has two inputs. They also have Infiniti-specific adapters that you can use so that no cutting is necessary. All of this info is available on the website linked above, which I don't think you've looked at...
Old Aug 7, 2006 | 11:06 AM
I did look at it but it was 4 am i will look again!
Old Aug 10, 2006 | 12:29 PM
does anyone have a pic of a RGB output so I can see what it lookings like?
