Problem: Auto resetting EQ adjustments
Old Aug 14, 2006 | 11:01 AM
djlittlewonder's Avatar
Exclamation Problem: Auto resetting EQ adjustments
It's been written about before, where, after you turn off your car, the radio EQ values appear the same (ie bass: +4, treble: +3) but the sound is actually flat (ie bass: 0, treble: 0). Well, after a while, I discovered that if you raise the volume past 19, the sound returns to the displayed EQ values.
Think that's the way it was meant to be? Or is it an annoying glitch. Does this still happen in the 06's and 07's?
Old Aug 14, 2006 | 06:32 PM
Igor911's Avatar
Just take it into service and get a new radio or w/e they will order under warrenty.
My 05 never did that
Old Aug 14, 2006 | 07:41 PM
rob40wilson03's Avatar
second thread on this exact topic i've seen today....
here's the other
https://g35driver.com/forums/audio-video-electronics/112067-anyone-ever-get-fix-radio.html
Old Aug 14, 2006 | 08:34 PM
badtziscool's Avatar
I have an 05 and it does it. At first, when I first got the car, it didn't do it. I was thinking to myself, "I must be lucky for my radio to not do that". Then it finally happened. The weird thing was that I started noticing the symptom when my radio did something glitchy. I started up the motor, turned on the radio, and nothing would happen. I'd see some weird text on the display but that was it. I couldn't turn it off, adjust the settings or anything. Then I turned off my car, let it sit for 10 seconds, turned it back on and everything was normal, but it started to do the stupid bass/treble reset problem.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
