Aftermarket 2 way alarm
Old Oct 23, 2003 | 10:58 PM
afr0puff's Avatar
Supa Dupa Moderator
Re: Aftermarket 2 way alarm
I would have beat that guys a$$ if he had said that wal-mart comment to me. What a reject. You might want to try PMing Theeggman over at FreshAlloy. He has the most tricked out G35 and has a remote starter also. He probably got a really high-end model.
The autopage starter I have does go into a similar bypass mode when you remote start the vehicle. However, if you do not remote start the vehicle, the bypass isn't initiated. The autopage has an ignition tamper sensor which disables the vehicle when in "bypass" mode.
http://www.anythingbox.net
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Learned Hand
Oct 1, 2015 09:02 AM
