Dynamat
Old Oct 11, 2006 | 12:37 PM
boxa87's Avatar
HOW MUCH DOES THIS STUFF WEIGH per SQ FT??
Old Oct 11, 2006 | 12:48 PM
digital1986's Avatar
do everything in your trunk, take out the carpet and go underneath and anywhere you can see in the trunk
Old Oct 11, 2006 | 04:03 PM
shibal_z's Avatar
Sound deadening is good for everyone, wether you got a custom system or not.
For Road Noise:
-Sound deaden the four wheel wells. This will reduce MOST of the road noise that can be heard in the cabin.
For Custom Audio:
-Sound deaden the four wheel wells to reduce outside noise.
-Sound deaden the doors to minimize reverb and rattle from the component speakers.
-If you have a sub, sound deadening the entire trunk (lid, floor, deck, etc.) is recommended.
-If you got extra material left, test your system, listen for spot rattles/vibrations and fix as needed. Foam blocks from a hardware store, wire ties, and various fasteners can alleviate most of your rattle issues.
Old Oct 11, 2006 | 05:20 PM
Clean G 4D's Avatar
Would the asphalt stuff melt in socal summer heat?
Old Oct 11, 2006 | 05:23 PM
bambam26's Avatar
Possibly, I know people there that have it and it didn't melt and I know people there that had it and it did. You hit or miss. I used the edead cause it was cheap and it was butle which is the new product these companies use so it doesn't melt. Plus on some cars when it gets hot you will smell the asphalt because it has heated up so much.
Old Oct 11, 2006 | 05:26 PM
shibal_z's Avatar
The asphalt based deadeners are much heavier and are more prone to temperature changes which will change the performance dynamics of the deadener. Butyl based deadeners are lighter and has a better operating temperature range e.g. Dynamat Extreme or like products.
Old Oct 11, 2006 | 07:14 PM
Jining's Avatar
i think it weighs like .35 lb per square foot roughly.
g.spot
May 9, 2016 10:54 PM
MikeyMike
Jan 27, 2007 10:25 PM
caelric
Apr 28, 2005 06:04 PM
cryhavok
May 20, 2004 05:06 PM
SoCalTed
May 14, 2004 04:51 PM
