Please help me decide on sound system!!
Here is a link for double-din install w/instructions on how to solder the dual climate control button.
http://g-owners.com/article_read.asp?id=33
Personally, the Z1 is not a SQ focused HU. It's geared more for people wanting everything in one box. Nav, radio, cool graphics, tuner tools, etc... I've talked to the installers at the shop I use and they are not down with the Pioneer D, N, Z units for people looking for SQ. The Kenwood DDX-8017 is a better SQ choice IMO, but you lose the Nav function unless you get a separate nav component. The other alternative I discussed with installers is to get the Alpine W200 double-din mated with their H701 processor to boost preout voltage and increase EQ control. The big plus is that the H701 can be managed using the onscreen interface on the W200, but again, you lose the nav function unless you get a separate component. So if SQ is more important to you than Nav, I'd look away from the D, N, and Z series all-in-one units.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
mjfenix
Aug 17, 2017 05:49 AM
