Adding aftermarket subs to 2006 bose system AND keeping stock sub???
Old Oct 22, 2006 | 06:07 PM
BlackStevo8's Avatar
i'd like to add just 1 or 2 subs with an aftermarket amp but also keep my stock sub working. is this possible with a LOC? i was just reading the sticky on the top of this thread but i wasnt sure if it explains what I need because it talks about using an amp for the stock door speakers. thanks in advance!!!
-Steve
Old Oct 22, 2006 | 07:56 PM
redlude97's Avatar
Depends on the amp, most people have been able to tap directly into the lineouts into the bose amp, converting them to rca's and plugging directly into the amps. This works with JL audio amps, which seem to be the most popular setup. I've gotten it to work with Alpine amps as well without an LOC.
Old Oct 22, 2006 | 07:57 PM
redlude97's Avatar
wait, do you have a coupe? they don't have a stock sub
Old Oct 23, 2006 | 08:50 AM
yea i have a coupe, they dont have stock subs??? wheres all that base come from then? lol. is there any wiring diagram you know of of where to tap into the stock bose amp? and which alpine amp do you have? I'll use whatever will work best, i just want a 600-1000 watt amp and probably 2 decent 12" subs
Old Oct 23, 2006 | 12:40 PM
redlude97's Avatar
Stock and bass shouldn't be included in the same sentence. The bose system is weak. My setup is an elemental designs 11kv.2 with an alpine mrp-350 with a custom box. If you want that much power I suggest a jl audio 1000.1 with a pair of ED 13ov.2s so that you might have some trunk space left over. a pair JL 12w6v2s could also work but will require an even larger box. I would suggest you rethink using 2 12" subs and either go with 2 10s in 4080 boxes or 1 12 in a custom box
Old Oct 23, 2006 | 07:35 PM
anyone know where to get a diagram to tap off the stock bose system??
Old Oct 23, 2006 | 09:17 PM
ON's Avatar
ON
https://g35driver.com/forums/questionable-posts/107029-sticky-all-2003-2006-g35-coupes-service-manual-pdf-format.html
its in the service manual. just dl and look through it. has all the wiring diagrams for it.
Old Nov 28, 2006 | 08:37 PM
dreamweaver's Avatar
I added a bass link II to my coupe and kept 6x9 bose hooked up... it sounded nice but now im ready to step the whole project up... soon be selling my brand new in box Infinity 6010cs (for the rear).two ohm matched for stock bose amp. and a pair of Infinity components 60.7cs used for 3 months. with basslink II sub... My friend talked me into doing a total system, but what i had sounded quite nice if you not into soundpressure plus...
Old Nov 29, 2006 | 01:33 PM
GreenGoblin's Avatar
The goblin resurrection
I think that the stock Bose system is pretty good for a stock car it is not the best but it never was intended to be
Old Jan 15, 2007 | 07:24 PM
s2k_g35's Avatar
https://g35driver.com/forums/showthread.php?t=107029
how come i can't view the link.
s2k_g35, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Old Jan 17, 2007 | 12:07 PM
surand1's Avatar
I'm getting the same problem:
"surand1, you do not have permission to access this page. This could be due to one of several reasons:
1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation."
EnCr1pt3d
Jul 8, 2019 02:48 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
BlackGee35
Jul 21, 2015 07:24 PM
