Car Alarm Recommendations?
Old Nov 3, 2006 | 06:15 PM
MD_V35's Avatar
Originally Posted by Otacon132
is this a new feature? if so i want an alarm system now, i researched on this a long while back and from what i found that manual cars are nearly imposisble to make them not start if in gear - due to the fact that there is no sensor in the car to tell it its in gear - can anyone confirm this?
Ya I think it is fairly new, the compustar alarms do this aswell
Old Nov 4, 2006 | 05:16 PM
Otacon132's Avatar
i called up sound advice today regarding the manual tranny and autostart....they said they have no diea about it and it is not recommended to install the autostart feature on the manual car.
guess im gonna call some other places and look around
Old Nov 4, 2006 | 08:33 PM
bb996+r1's Avatar
Viper 791XV 2 way paging, remote start( I would on recommend only using it on a auto). I had one on my Navigator and loved it.
Old Nov 4, 2006 | 08:35 PM
bb996+r1's Avatar
Yea, you are right we won't do it because of liability.
Old Nov 4, 2006 | 11:03 PM
Otacon132's Avatar
i totally agree with that, and i wouldnt do it on a manual car, just that for a second i figured somehow they came up with a way to prevent it from starting in gear.
Old Nov 4, 2006 | 11:16 PM
MD_V35's Avatar
There is a way to prevent starting it in first gear...look up compustar, they make a special autostarter for manuals that determines if you are in gear or not when you turn off the car, called reservation mode, in order to be in reservation mode you must turn off the car with the parking brake engaged, in neutral, and with your foot off the brake, the car will stay on for 2 minutes then automatically turn off and when you want to auto-start the car you just press the button and your car should start. This may sound like a tedious task but it's very simple. I have the compustar installed in my 6MT and I cannot start it in gear only in neutral.
Old Nov 4, 2006 | 11:20 PM
2006_G_coupe's Avatar
talk to mike the installer at the one in aventura..he did mine on the side..
Old Nov 5, 2006 | 12:55 PM
thintzen's Avatar
audiovox or prestige..same thing is a good alarm as well. i'm using the aps-997...good alarm too
Old Nov 6, 2006 | 08:45 AM
Gilley's Avatar
As bad as our ebrakes are, why would you not want to keep your manual transmission in gear when the car is parked? Thus, the autostart would be useless anyway.
Old Nov 6, 2006 | 11:45 AM
JEVERYDAY's Avatar
Viper 791 .... Hasnt failed me yet
Old Nov 6, 2006 | 11:49 AM
KPierson's Avatar
Almost every fuel injected Nissan has a PNP (Park/Neutral Position) switch that sends out a (-) signal ONLY when the tranny is in either N or Park. This signal can be used to prevent the car from starting in any gear.
I only park with my car in gear if I'm on an incline that warrants it. Most of the time mine is left in N, and I don't even have a remote start on it!
Old Nov 9, 2006 | 10:08 PM
bullitproof's Avatar
I have this on my 6mt with window roll up-down, back-up battery and glass break. i learned to drive using the e-brake and putting the car in nuetral. plus i use the turbo timer feature included in the alarm so when i leave the car its always in nuetral.
Old Nov 26, 2006 | 11:14 PM
vietfob714's Avatar
Viper
Old Nov 27, 2006 | 03:49 AM
G-MENTED's Avatar
get a crimestopper. haha jk
Old Nov 27, 2006 | 09:30 AM
  #30
GreenGoblin's Avatar
The goblin resurrection
mine ebrake is garbage and if I left it in neutral it would be in the middle of the road. is there any way to adjust the ebrake cable
