Car Alarm Recommendations?
Old Nov 27, 2006 | 08:38 PM
  #31
Otacon132's Avatar
Originally Posted by KPierson
Almost every fuel injected Nissan has a PNP (Park/Neutral Position) switch that sends out a (-) signal ONLY when the tranny is in either N or Park. This signal can be used to prevent the car from starting in any gear.
I only park with my car in gear if I'm on an incline that warrants it. Most of the time mine is left in N, and I don't even have a remote start on it!
anyone able to confirm this is the wire?
Old Nov 27, 2006 | 09:24 PM
  #32
KPierson's Avatar
Thats exactly the wire, but you are looking on the wrong end. Check out the EC.pdf file, around page 100 your will find the pinout for the ECU. Look for the P/NP switch input. That will be your wire.
Old Nov 27, 2006 | 09:55 PM
  #33
Otacon132's Avatar
hmmmmm i quickly skimmed through it.....gotta go out but ill check later, i coudlnt find it =\
Old Nov 27, 2006 | 10:32 PM
  #34
wayneside's Avatar
autopage is nice...thats what i have...
the biggest part about the alarm is make sure you have a great installer otherwise you will be in a world of problems!!!
Old Nov 28, 2006 | 02:35 AM
  #35
Otacon132's Avatar
is this the other side of that?
Old Nov 28, 2006 | 06:54 AM
  #36
KPierson's Avatar
Yeah, that's it. The ECU is behind the glovebox.
Old Nov 28, 2006 | 03:23 PM
  #37
Otacon132's Avatar
well, just got off the phone with an installer who says he owns a g 6mt and didnt put the autostart cause he didnt want the manual/gear problem. Told him about this, and was told it would fry the ECU.....i dont understand how its possible, is he just a doutch who doesnt know what he's talking about or would there be something else to it?
Old Nov 28, 2006 | 05:13 PM
  #38
KPierson's Avatar
He is wrong. Look at the schematic. The P/NP switch is physically mounted in the tranny. One side is connected to ground, the other side goes to the ECU.
When you read the ground off of the signal, you are reading it THROUGH the switch, NOT from the ECU. The ECU pin is an INPUT, not an output.
DRG35R
Jul 31, 2015 10:23 AM
multimut
Canada
Jul 26, 2015 08:43 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
Soumilg
Jul 18, 2015 12:33 PM
