Help w/ 2003 G35 Install
after spending time searching i was unable to answer this:
I am installing an aftermarket head unit in a 2003 G35. I understand i need the a/c controller from Grubb's Performance (or others) because mine is integrated into my radio. I am building my own trim ring and dont need brackets as i will make my own if needed.
My question.There are four plugs in the back of my radio and 1 plug from the top of the a/c controller.When i purchase the wiring harness for the new radio i will be using two of the four plugs. This leaves two plugs left plus the a/c controller plug. The new a/c controller from Grubbs performance has 1 plug. That means i have 2 plugs still left!!Are they for the built in cd changer??
I unhooked all four oem plugs and left the oem a/c controller plugged in but still was unable to control the heat. I am worried if the buy the Grubbs performance controller i still wont have heat controls.
Can anyone help?? Thanks. Im a newbie!
yes that is correct 2 will be left. the a/c is also integrated into the radio board, so that is why it did not work. the jdm a/c will take care of that fine. many ppl have done this mod already.
TWASkyliner
Feb 8, 2020 08:00 PM
Rehman2009
Jul 27, 2015 03:23 AM
