Need help on a design..
Old Nov 12, 2003 | 03:25 PM
infidsg35's Avatar
I have 2 Rockford 12" HX2 subs. I realy dont feel like buying new one plus these sound realy good.. Anyways I need to come up with a design so I can fit the 2 subs and 2 amps. The amps are no problem but the subs for me are..
I suck *** at math and can make a enclosure to save my life. I know what to use to make it: 3/4 Inch MDF, Liquid Nails ect.
Im thinking of putting the amps in the rear by the rear seat in the cubby hole. As far as the subs I was thinking of putting them on the sides of the trunk angled towards the opposite ends of the trunk.. Does anyone have any ideas for me or what I can try or pics?
Any help would be great.. This might be a lil unclear so write me if you have any questions.. Thanx
5 wire Grounding kit
350z Pipe / Stillen High-Flow
JUN Flywheel
Crawford Intake Manifold
Best 1/4 14.153 @ 99.19 / 2.29 - 60'
Old Nov 12, 2003 | 06:07 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Need help on a design..
You need to be a little more specific on your goals for your system. Is loss of trunk space an issue? Do you want a tight sound or a lot of "boom"? Is a custom fiberglass enclosure in your budget? There's a lot of people on here with some custom sub enclosures but they all had these things in mind. Also, where do you want these to go? By the tailights?
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Nov 13, 2003 | 08:12 AM
infidsg35's Avatar
well thats the thing I kinda want to put the amp rack as far back into that cubby hole as possible. As far as the subs I want to make 2 seporate enclosures one on each side of the trunk. Since they are 12's im going to have to angle them back a lil.. But im not sure how thats going to sound.. I would LOVE to put the subs under the rear deck and the amps on the sides but im not sure how thats possible.. I want to try to keep in the spare with some kind of access to it.. But if impossible will consider going without it..
So I realy want the box in that back cubby but how would that design work? Isnt the hight only about 12"? But If its not possible to do this then I would try to put them near the taillights. If anyone has any suggestions on how to keep the spare and put in 12" subs please tell me your idea.
As far as budget its high as im not going to finish this for a month or soo I want to take my time. As far as fiberglass I have necer worked with the stuff and not even sure how it works or even how to do it.. So im not sure on that 1. As far as sound I want a more tight bass not sloppy never ending bass.. Thats why I want it in a sealed box.
JUN Flywheel
ibg
Feb 20, 2014 02:59 PM
AgentRice
SFL G CLUB
Oct 15, 2009 12:23 AM
CarNutz
Feb 24, 2007 12:57 AM
C_J_GO
Dec 9, 2006 08:10 PM
Raznips
Nov 5, 2005 02:01 AM
