Ohms...
Old Jan 5, 2007 | 05:34 PM
extreme4377's Avatar
Lexus IS350
Ohms...
Im about to install my sub and amp, but I ran into a small issue. Do I want to configure the sub to be 2 ohms or 8 ohms? Thanks
Andrew
Old Jan 5, 2007 | 05:53 PM
erdog's Avatar
Try cardomain's subwoofer wiring config: http://www.cardomain.com/shop/woofer..._subs=4%20ohms
saitcho's Avatar
it depends on what your amp can handle. most likely you want to configure it for a 2ohm load if your amp can handle that
Old Jan 5, 2007 | 05:58 PM
redlude97's Avatar
is your sub a dual voice coil sub and what are the resistances on the individual voice coils, that will determine which configurations you can achieve
Old Jan 5, 2007 | 07:07 PM
Lexus IS350
Ive got what is listed in my sig, JL 500/1 and a 10W6V2 D4
Thanks..
Old Jan 5, 2007 | 08:14 PM
k67p67's Avatar
The 500/1 features JL Audio's "Regulated Intelligent Power Supply". It is intended to maintain consistent, linear power output. The 500/1 is rated @ 500WRMS 1.5-4.0 ohms. I'm not sure it's rated for an 8-ohm load. You should be running the voice coils in parallel to present a 2-ohm load to the amp.
Old Jan 6, 2007 | 12:18 AM
ltrrtl218's Avatar
yea redlude97 is right...i saw on ur sig it said u have a w6v2 and a 500/1. the sub is a dual voice coil 4 ohm sub which means u wire it at 2ohms
Old Jan 6, 2007 | 01:52 AM
redlude97's Avatar
Yeah, I needed to know if your VCs were D4 or D2, but to get a 2ohm resistance, wire them in parallel, which means hooking positive to positive and negative to negative, and then connecting to the amp. Easiest way to do this is the connect 2 short wires to each of the positive and negative connections, and then running the longer wire to the amp from one of the voice coils
nchima
May 11, 2012 12:59 AM
06g35meister
Jan 3, 2008 02:43 PM
