03 Double din kit for Z1 ?
Old Jan 6, 2007 | 08:41 AM
edindaclub's Avatar
I have the 03 OEM nav and wants to upgrade to the Pionner Z1, wut do i need? the Double Din Kit and the Ac controller and the double din bracket with navigation??? am i correct ?? please help me here
Old Jan 6, 2007 | 10:29 AM
HipHopPro's Avatar
No bracket needed, just use the one you have.
Old Jan 6, 2007 | 11:14 AM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Question
So what purpose does the new bracket serve different from the stock bracket? I mean why even sale it if its not needed. I'm just curious because I bought all my parts except the bracket and I keep thinkin I'll have to do some extra drilling since I didn't get it. What the difference between them
Old Jan 6, 2007 | 11:20 AM
brianyun's Avatar
ill buy the old navi off of you. can you even install the navi to one that didint come with navi?
Old Jan 6, 2007 | 11:25 AM
Callaway's Avatar
Anything is possible, but is it worth the time and money to retrofit? Hell no IMO.
Old Jan 6, 2007 | 01:00 PM
Calvin's Avatar
Overglorified Altima
yeh you can but its a PITA and not worth the time/trouble
Old Jan 6, 2007 | 01:40 PM
Meatshackle's Avatar
Deep Sea Moderator
The only difference in the brackets is the holes to mount your new head unit or housing. The new bracket has 4 holes in a square pattern whereas the factory bracket holes aren't quite square. As stated above you can still mount an aftermarket head unit on the factory bracket.
I ordered it because at the time nobody knew for sure if you needed it for an '03 coupe with nav. The holes lined up with the holes on my Alpine marked "Nis".
Old Jan 6, 2007 | 09:43 PM
Drtybrd61's Avatar
from what I've heard, you may have to do some drilling on the factory bracket to get everything to fit...ALSO, I've heard that the stock bracket might not allow for a flush sitting of your new HU. When I got mine installed, I asked the guys at Super Autobacs if I needed and they said the last guy they did the install for had it and everything worked out perfectly. So with that recommendation I got the bracket and I'd say everything worked out really good. Here's a link to my thread with pix https://g35driver.com/forums/audio-video-electronics/119268-willow-dd-finsiher.html
Old Jan 6, 2007 | 09:50 PM
htownboy's Avatar
When mine was done the had to drill 2 small holes in the original to keeop from using the new bracket... The Double Din and AC controls came from Grubbs Infiniti, they have a fair price for them.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Vanessarino
Audio/Video/Electronics
Sep 12, 2015 10:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
