PS2- Glove Compartment - Electric
Old Jan 24, 2007 | 07:32 PM
schin101's Avatar
For those of you that have the mod to make your OEM NAV have a video input that use the PS2 Slim, How do you power the PS2? Please try to be as detailed as possible as I plan on doing this, this weekend. Thanks Let me know what product I need and which wires to get the power from.
Old Jan 24, 2007 | 08:15 PM
Meatshackle's Avatar
Deep Sea Moderator
Hardwire an invertor. Get the power from the battery or if you get a small invertor you can use the passenger or driver side 12 volt/cig lighter.
Old Jan 24, 2007 | 08:19 PM
schin101's Avatar
I'd probably rather not get it direct from the battery. If I leave the PS2 on my car is dead. But lets say I did get that, how would I hardwire it?
Old Jan 24, 2007 | 09:10 PM
Hi-TechG35's Avatar
Hardwire the power inverter with a fuse and relay to the cig lighter. I've done this mod for a few friends. you have to cut the end of the power inverter where the cig plug is test it to see which is negative and positive. Connect a relay with a fuse to the positive and splice into your cig lighter or 12 volt power source. Most inverters have a power on/off switch.
Old Jan 24, 2007 | 09:13 PM
Hi-TechG35's Avatar
Heres a DYI link for you
http://caraudio.biggz.com/installati...rinverter.html
Old Jan 24, 2007 | 09:18 PM
schin101's Avatar
I understand that it would have a on/off I'm just worried I'd forget to shut it off.
Old Jan 24, 2007 | 09:23 PM
redlude97's Avatar
Run a relay inline with the power connected to your ignition source so it shuts off when you turn the car off
Old Jan 24, 2007 | 11:32 PM
Deep Sea Moderator
Why would you need a relay? The invertor has a switch and he's wiring to a switched power.
Old Jan 25, 2007 | 12:18 AM
redlude97's Avatar
I wouldn't recommend tapping directly into a switched source, a power invertor usually requires more current than a cig lighter wire can supply and you run the risk of an electrical fire. Rather, tap into that line for the relay turn on lead, and run the power wire directly from your battery.
Old Jan 25, 2007 | 02:32 AM
Deep Sea Moderator
I understand what you're saying because the cig lighter is only rated at 15amps.
Hitechg said to wire a relay with a fuse to and use the cig lighter for power. That's the part I didn't understand.
Old Jan 25, 2007 | 11:52 AM
SFLG35's Avatar
FGC President
i got a cigarette lighter power supply for my ps2 at eb games and took it apart and then connected the wires to the to the wires behind the cigarette lighter.
although i think i am goin to move them to a constant source that way when i turn the car off and on i dont loose what im doin on the ps2.
Old Jan 25, 2007 | 12:01 PM
Hi-TechG35's Avatar
Better safe than sorry. I know the inverter has a switch but I've had a couple of the switches burn out causing a surge so I use an extra relay as a just in case.
Old Jan 28, 2007 | 09:06 PM
Down_Shift's Avatar
you don't need a relay.. there is a fuse on the inverter..
Find ignition power source and get it from there.
Old Jan 28, 2007 | 09:12 PM
ttrank's Avatar
Grocery getter
Just get the contant power from the battery (with a fuse)and the switched power for the relay from the lighter. It won't draw any power from the lighter and will use solid battery power for it.
Old Jan 29, 2007 | 12:49 AM
Deep Sea Moderator
If you get power from the battery you might as well just put a switch on that instead of a relay. It's less wiring and with that setup you have the option to leave your invertor/ps2 on while the car is shut off. Like Dan was saying you won't lose what you're doing.
I've had mine wired like that since '03 and I've used that little feature more than I ever thought I would need to. You can pause movies, shut the car off, go into a store (gas, 7 eleven, restaurant, etc), and come out and you don't have to find your place or wait for everything to load all over again.
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
RA081024
Interior
Oct 27, 2015 07:27 PM
vamarris
Sep 26, 2015 12:56 PM
RA081024
Sep 18, 2015 12:20 PM
