Removing the radio.
Old Feb 17, 2007 | 08:05 PM
marcelkatz's Avatar
Removing the radio.
I know , i know, i already checked in the do it yourself. its not there.
Here is my problem, i tried to take out my friends AMP and after disconecting it the air doesnt work, radio and etc either. so i am trying to disconnect the amps wires from the back of the radio. HOW DO I REMOVE THE RADIO? someone please hlep me out the car is sitting out here haha
Old Feb 17, 2007 | 08:42 PM
marcelkatz's Avatar
i really need some help here with removing the radio in my friends coupe
Old Feb 17, 2007 | 08:43 PM
marcelkatz's Avatar
how do i remove it!? like the whole console
Old Feb 17, 2007 | 08:54 PM
marcelkatz's Avatar
Help
Old Feb 17, 2007 | 09:50 PM
Meatshackle's Avatar
Deep Sea Moderator
Did you look in the AUDIO section? That might be a good place to start.
Old Feb 17, 2007 | 09:52 PM
Hi-TechG35's Avatar
Is it aftermarket or stock?
Old Feb 17, 2007 | 09:53 PM
Hi-TechG35's Avatar
Also check the fuses to make sure you didn't blow the fuses.
Old Feb 18, 2007 | 08:30 AM
DHCrocks's Avatar
air doesn't work becuase the incab temp sensor is unplugged. it's on the drivers side underdash panel. it looks like a black hose maybe 1/2" diameter and a electrical terminal. This is the most likely culprit.
To remove the radio, you need to remove the clock trim piece, there's a bolt there. I'm assuming you got the radio trim piece off already.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
