Blown Sub!
Old Mar 1, 2007 | 11:13 AM
g's uppp's Avatar
Blown Sub!
I have a JL W6 in my car and it sounded weirded so I checked my trunk and there was a tear in the sub. Has anybody else experienced this problem and what could be the reason it tore.
Old Mar 1, 2007 | 11:41 AM
redlude97's Avatar
Did it tear all the way around or just in a small spot, if its a small spot, likely something in your trunk ripped the surround rather than the sub actually blowing it. The rip was probably significantly smaller, but the sub movement probably kept enlarging it until you noticed. Surrounds, especially on high end subs rarely fail nowadays, and when they do it usually the result of delamination rather than actual tearing
Old Mar 1, 2007 | 02:05 PM
16psibrick's Avatar
+2
is it protected? did anyhting ahppen when it ws installed?
a common installer mistake is whent hey are screwing the sub in, they slip and jab the surround. often, this will make only a tiny indent or invisible hole in the surround, so they dont realize or say anyhting...
but then over time, as said above, it gets larger and larger...
the only way a surround will fail on something like a w6 due to normal usage, no overpowering, is the entire surround delaminating and coming off the basket of the sub, again as mentioned above
Old Mar 1, 2007 | 04:20 PM
kdawg's Avatar
until we know more details like what kind of tear and if the sub is older and perhaps had a smaller rip before we ant effectively diagnose.
Old Mar 4, 2007 | 01:03 AM
G'duprideR6's Avatar
I just blown my 2nd W6 about a week ago. Yes, 2ND! in less than a yr. Probably my fault being an idiot bumping it too much.
Old Mar 4, 2007 | 01:13 AM
Hi-TechG35's Avatar
What amp are you running?
Old Mar 4, 2007 | 11:54 PM
JL Audio 500/1
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Eomfd
Aug 29, 2015 12:42 AM
