AVIC-D2 Replacement?
Old Mar 26, 2007 | 08:32 AM
Gilley's Avatar
Originally Posted by pleiboprang
Didn't know I had to replace the amp? What amp would you recommend? Could I do it myself? I'm a machinist & lean more to the mechanical end.
I could follw instructions if they are supplied.
Which Alpine unit do you like? I would like something with double din touch screen, AM/FM, Satilite, CD, DVD. Not a wiz at electronics & need a simple install. Thank you for your help.
If you don't have the Bose system, all you need is the harness adapter to power the OEM speakers with the D3.
If you have the Bose system, then you need to decide if you want to replace the Bose amp (which I always recommend) or use it. The Bose amp is the worst piece of equipment in the audio system.
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
