Wiring the Sub and Amp Help Needed!!
Old Dec 12, 2003 | 12:15 AM
VinNYCG's Avatar
G SQUAD
Just curious as to where you guys ran your wiring through from the battery to the back? Did you drill holes or what? I m having my stuff installed and the car is leased so I want this install done as neatly and stealthy as possible...Any tips? Do's and Donts? Thanks appreciate the help
Old Dec 13, 2003 | 06:17 PM
steveniemi's Avatar
Re: Wiring the Sub and Amp Help Needed!!
On the passenger side under the windshield wiper cowl is a large rubber grommet. Carefully pierce it and drop your wire into the passenger compartment. you'll have to remove all the plastic parts around the battery and windshield cowl on the pass. side
Old Dec 14, 2003 | 08:39 PM
VinNYCG's Avatar
G SQUAD
is it hard to disassemble those stuff
Old Dec 14, 2003 | 08:40 PM
VinNYCG's Avatar
G SQUAD
no hole drilling required?
Old Dec 14, 2003 | 11:29 PM
ericinmia's Avatar
https://g35driver.com/forums/showfla...sb=5&part=&vc=
There are directions for getting the wire inside, then just run in under carpet to trunk...
hope this helps... and also...
When i cut into the top of the rubber gromet in the engine i tried to make the smallest insicion possible on the top not around the ring or bottom, and water still came inside even after covered nicely in electrical tape... i eventually bought some GE silcone 2 in black, and covered the electircal tape with it... it fills the gaps and seals it all... now all is good, and no water comes into the cabin!
Any other ?'s
Peace
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Dec 15, 2003 | 01:42 AM
VinNYCG's Avatar
G SQUAD
Hey thanks Eric...Well instead of questions, what do you think I should tell the installers who are doing the install. I just dont want to have to deal with any mistakes you know. So I'd rather get it all done with. Thanks I appreciate it
Old Dec 15, 2003 | 10:28 AM
ericinmia's Avatar
Even though there is a hood, and then a battery compartment cover, and seals around it... when you wash your car or it rains hard water will get in there so tell them the gromet has to remain waterproof because water will douse it occasionally... and it will end up on the passenger side floor if not taken care off!
Peace
-Eric
Old Dec 15, 2003 | 05:28 PM
VinNYCG's Avatar
G SQUAD
Thanks once again bro, I'll be sure to let them know
Old Dec 16, 2003 | 01:30 PM
RacerX's Avatar
I found it better to NOT cut the grommet. The grommet on my sedan was conneced to a 4" long rubber tube, all gummed up with sticky sealant tape. I unwapped all the sticky tape, the inserted my 4 Gauge amp power cable right into to tube. I then sealed to whole assembly back up with electrical tape. No leaks. No need to piece the grommet.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Frostbite91
Aug 12, 2015 05:16 PM
Karran Dhanroop
Aug 2, 2015 08:22 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
