Mounting an amp
Old Mar 22, 2007 | 09:54 AM
avengence's Avatar
Mounting an amp
Ok so I had my subwoofers installed in my car and I have a question about mounting an amp. I want to move the amp to a different position because right now my box takes up too much room so I was thinking of going with a different box. Where is the best place to mount the amp in the trunk area. I dont want to take out my spare tire or anything like that.
Old Mar 22, 2007 | 09:57 AM
izmir41500's Avatar
G35driver Addict
on the back seat
Old Mar 22, 2007 | 10:42 AM
gqong's Avatar
i mounted mine on the backseat using velcro.
Old Mar 22, 2007 | 11:10 AM
16psibrick's Avatar
Old Mar 22, 2007 | 11:20 AM
izmir41500's Avatar
G35driver Addict
Originally Posted by 16psibrick
back seat if yu do it right, or if its small ont the side:
https://g35driver.com/forums/showthread.php?t=138819
back seat install i did
https://g35driver.com/forums/showthread.php?t=125963
Good info man. I'll have to pm you in the future when I decide to put something together. probably the last thing i do though.
Old Mar 22, 2007 | 12:11 PM
Gilley's Avatar
Mine is mounted on top of the Bose amp bracket to the left of the spare tire. You'll have to trim the plastic spacer though. I wanted to retain the ability to fold down the rear seat and not worry about damaging the amp loading things in the passthrough.
Old Mar 22, 2007 | 01:01 PM
redlude97's Avatar
+1, thats where mine is mounted as well. About as stealth as you can get, but it only fits pretty small amps there
Old Mar 22, 2007 | 01:06 PM
omasica's Avatar
i put mine on the top or the back of the box
Old Mar 22, 2007 | 01:07 PM
izmir41500's Avatar
G35driver Addict
for those with the amps on top of the stock location: what amps are you runnin and which will fit?
Old Mar 22, 2007 | 01:33 PM
redlude97's Avatar
check sig
Old Mar 22, 2007 | 01:35 PM
Gilley's Avatar
I have a JL Audio 500/5.
Old Mar 22, 2007 | 03:13 PM
redlude97's Avatar
I you have a 500/5 did you remove the bose amp?
Old Mar 22, 2007 | 03:14 PM
Gilley's Avatar
I removed the Bose amp, but you don't have to. I just didn't want that piece of junk in the car.
Old Mar 22, 2007 | 03:19 PM
redlude97's Avatar
Just curious why you didn't remove the bracket as well so you can mount the amp lower and allow for more space for heat dissipation
Old Mar 22, 2007 | 04:19 PM
Gilley's Avatar
the amp bracket makes a nice rest and raises the amp off the floor to give a little more clearance without fabricating a new mounting bracket.
Here's a helpful thread to give you an idea. https://g35driver.com/forums/showthr...ighlight=trunk
