Factory Bose + HU upgrade
on
Where online can you get the scoche adpater OR the soundgate??and dont tell me WAL MART or someplace like that cause they wont have it here. i need online.
i want to do the exact same thing BUT i cant find that scoche adpater i want to change the components eventually next year but for now all i want to do is the HU
www.cardomain.com has the wiring harness for Bose as well as the antenna for upgraded units...
Scosche NN03 $9.95
http://www.cardomain.com/item/SCONN03B
for Bose will need:
Scosche FAI-3A $33.95:
http://www.cardomain.com/item/SCOFAI3
for Bose will need:
Get a DD with RCA outputs. Get some old RCA cables, cut them and then splice each plug so you have the bare wires (+ and -). Connect them in accordance with your wiring harness. This converts the output of radio to Low voltage as the bose requires and it will work fine. So you will run the RCA plugs out of new radio directly to factory wiring to bose unit.
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
DEMoLITIoN
04-20-2016 06:57 PM
