need a good thread on how to hardwire radar?
Old Apr 11, 2007 | 09:08 PM
fastGkid's Avatar
can someone please help. one with pics and good explanation on how to hardwire 8500 x50 radar detector.
i have searched and couldn't find anything with a good long explanation and pictures.
thanks
Old Apr 11, 2007 | 09:11 PM
bb996+r1's Avatar
Have u seen this?
https://g35driver.com/forums/audio-video-electronics/149626-just-received-my-escort-9500i.html
Old Apr 11, 2007 | 09:12 PM
speedracerg35's Avatar
i would suggest buying a mikes mirror mount and hardwire it to your mirror.
Old Apr 12, 2007 | 12:14 PM
fastGkid's Avatar
bump
Old Apr 13, 2007 | 09:11 AM
allendoc's Avatar
In my Z I had the Escort Passport SRX, the laser shifters saved me 3 times in 2 years. The radar receiver is bigger than most window mounted Radar Detectors. I had only 120 miles on my G35c when I took off the from clip and installed a Bel RX75 Pro, which is almost exactly the same as the SRX. 2 major differences, on threat mode, the SRX would show be up to 3 KAs, 3 Ks and 4 Xs at the same time with little bar graphs. The Bel will only show you the highest strength signal in each band, but still does show Ka and K threats at the same time with a number up to 9. The second major difference, about $1000! You can get the Bel RX75 Pro for around $500. Bell calls the Laser Jamming Blocking verse shifting. From installing 4 kits now, 2 of each, I can tell you they are exactly the same. The Bel actually has a better looking display, but the SRX shows more info. I went with the BEL, very well spent $500.
I have not yet taken the time to finish my DIY, but I do have all the pictures from my G's install. When you look at the front of my car, you can barely see the shifters, but I did cut the "honey cone" area on both sides and they do have a clean view at the road ahead. The picture would explain it better. My little display sits behind my steering wheel and is so slim I can still see all my gauges.
This is with out a doubt the best protection. As we all know, we only feel like we are doing 45, and the speedo says we are going a little quicker. And the best part, no one knows i have a radar detector. I drive on to a military base every day, it just looks like I have a turbo timer.
This is the best way to hard wire a radar detector and laser jammer!
Old Apr 13, 2007 | 09:19 AM
O NO's Avatar
Staff ALUMNI
Originally Posted by fastGkid
bump
Why the bump bro
Search is your friend.
Get off ur rear end and do some legwork for your question. Over time there have been several threads about this.
Look up in the diy area. Use different wording in your search. Don't be specific to the detector you're using etc.
If it's around, it probably will be on Driver. Good luk with it.
Old Apr 13, 2007 | 09:22 AM
izmir41500's Avatar
G35driver Addict
Originally Posted by bb996+r1
Yes. check this thread out, there are pics also.
Old Apr 13, 2007 | 11:23 AM
fastGkid's Avatar
Originally Posted by O NO
Why the bump bro
thanks bud i've searched every page and still havn't found the one i'm looking for. thanks though
Old Apr 13, 2007 | 05:33 PM
bb996+r1's Avatar
I don't get it, I mapped it out.
Old Apr 13, 2007 | 05:34 PM
tony's Avatar
Where are you located?
Old Apr 13, 2007 | 05:41 PM
bb996+r1's Avatar
Pretty cool mounting option. But at my old store (higher end area) we would etch them in the rear view mirror.
Check out the rear view mirror. SR7 &ZR3
Attached Thumbnails need a good thread on how to hardwire radar?-760ilradar5.jpg
Old Apr 13, 2007 | 05:47 PM
BadBoy06's Avatar
that should help you out..mikes mount with invisi cord..works
for my 8500
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
kinetek
Aug 3, 2015 04:25 PM
BlackGee35
Jul 31, 2015 11:04 AM
