DIY for add a sub + amp???
Old Apr 30, 2007 | 02:40 PM
wuyichao's Avatar
is there a diy for adding a sub and a amp
i recently bought a jl audio 10w6v2 and 500/1
i want to diy it, so im wondering if there is a diy thread or anything related to it that will help me?
thanks
Old Apr 30, 2007 | 02:54 PM
Hi-TechG35's Avatar
Yep check in the tech section in audio/video
Old Apr 30, 2007 | 03:19 PM
Gilley's Avatar
It makes a big difference whether you have the Bose system or not.
Old Apr 30, 2007 | 03:27 PM
wuyichao's Avatar
i have boss system
Old Apr 30, 2007 | 03:41 PM
Gilley's Avatar
Having the Bose system makes it much easier to connect a amp for your sub since all the wires are already run to your trunk. There are some DIY's in the Audio section.
Old May 1, 2007 | 02:33 AM
extreme4377's Avatar
Lexus IS350
https://g35driver.com/forums/audio-video-electronics/101293-diy-add-sub-your-bose-equipped-g35-coupe.html
That's a very, very helpful guide. Just make sure you follow it to the T and you'll be set. Best of luck!
Old May 1, 2007 | 02:56 AM
wuyichao's Avatar
thanks
few questions regarding installation before i start doing it
1.what wires do i need to splice in order to connect them to the amp
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
are these the only wires or there are more that i need to splice?
2.do i have to disconnect the rear 6x9 speakers? if so, how do i reach those speakers?
3.i also have JL Audio XA-PCS4-1 4 gauge cable, do i need to buy anything else to hook my sub and amp up?
4.how do everyone run their red power cable under the carpet? what do u need to remove?
5.what is this wire, and where do i connect this to?(in the pic)
thanks
Old May 1, 2007 | 12:06 PM
wuyichao's Avatar
anyone?
Old May 1, 2007 | 11:06 PM
Sponger's Avatar
6MT Brembo Coupe
Here you go...
**You need one more wire from the blue harness. It's blue/silver and for the remote turn-on for your amp.**
**You need have to, but some have. I left mine connected. There's a post on how to remove the rear shelf speakers.**
**That will be more than adequate for constant +12V to your amp. Don't forget your ground, remote turn-on, and high quality speaker wires.**
**It's easy once you get thru the firewall. Simply unclip the door sill panel and tuck the wire underneath the carpet.**
**It's a line converter that you can get at any car audio shop. The best way to tap into the blue harness is to strip a 1/4" on the insulation, poke through the strands, insert and wrap converter wire, and then solder. You can use splice connectors, but I don't trust them in the long run.**
Old May 1, 2007 | 11:18 PM
Steel Blue's Avatar
What do you need the line converter for?
Old May 1, 2007 | 11:27 PM
NivlekGT's Avatar
This is the link I'm going to use when I install my amp/sub combo in a few weeks.
https://g35driver.com/forums/showthread.php?t=101293
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
