Stock Wiring for speaker upgrade on Bose? '03 Sedan...
Old May 15, 2007 | 02:10 PM
ikSardarG's Avatar
Hey all,
Its been a while, but I thought I would check in with you as I plan a nice audio upgrade to my 2003.5 sedan w/ Bose.
I am doing a complete overhaul:
Stock headunit, with RF 3sixty.2 processor
JBL MKII components for front and rear, running off older MTX amps.
2-12" Polk DB Subs for the trunk, running from an MTX amp.
Plus other goodies.
I have read around on the net and seen that most factory speaker wiring is more than sufficient. Is this still true with the Bose? I would like to use the stock wiring if it is good, but than again - my JBL MKii components are failry high-end, and I dont want to waste the installation because I was too lazy to pull new wires in to the doors. I dont recall the exact wattage I will be sending to the fronts - but approx 120 watts per channel sounds right.
I have a hunch I should pull new wires. Any advice?
Thanks!
EnCr1pt3d
Jul 8, 2019 02:48 PM
mjfenix
Aug 17, 2017 05:49 AM
Daniel k.
Nov 3, 2015 09:52 AM
Thunderaan
Jul 22, 2015 07:40 PM
