OEM Nav Install
OEM Nav Install
Does anyone know how to install a factory navigation into a '03 Coupe? I'm assuming a bunch of you guys have taken them out, or at least seen all the plugs in the back and had an idea of how to install it. Dealer is charging way too much and would rather try and do it myself. Thanks!!
i would love to learn about this too, I have been shopping for stock NAV system and would like to lear/know about OEM NAV install in no-nav car. thanks for starting this thread.
I think only 1 person has succesfully done this, its not simple, and requires replacement of the entire interior wiring harness along with the install of the various nav components, much cheaper to just go aftermarket nav
As stated above you need to replace the main harness in the car. This is a very involved process, but can be done with enough time and patience.
I believe the guy reported that not all the functions worked properly after he was done (milage, maitenance, things like that) but that the Navi itself worked. You may need to swap out the cluster to get everything working right.
dd finisher, ac controller...
i wish they would just stickie this question. Whenever you dont know something, search for past threads.
HERE IS HOW YOU DO IT.
https://g35driver.com/forums/showthr...ght=navigation
OR get this screen (out of stock): http://store.mp3car.com/Infiniti_G35..._p/dsh-009.htm
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
