Swap out Sirius for XM with Traffic?
Old Jul 8, 2007 | 02:09 PM
thedilleyo's Avatar
Does anyone know if it's possible just to switch out the Sirius control box for an XM control box with NavTraffic? I don't want to have to replace the antenna or cables running to the radio. Is this possible?
Old Jul 9, 2007 | 12:47 PM
Gilley's Avatar
What car do you have?
Old Jul 9, 2007 | 01:11 PM
thedilleyo's Avatar
I have a 2004 G35 Sedan.
Old Jul 9, 2007 | 04:06 PM
jimmyshaker's Avatar
Oh man, if we can do that, that would be sweet.
But I highly doubt our 2004 Nav systems are capable of handling the traffic piece.
Old Jul 9, 2007 | 10:33 PM
thedilleyo's Avatar
I was actually hoping to replace my HU with an AVIC-D3 and just use the existing wiring and swap out the Sirius box in the trunk. Anyone know if that's possible.
Old Jul 9, 2007 | 10:49 PM
da mayor's Avatar
nav traffic is not suported in any G older than 06MY. better go aftermarket
Old Jul 10, 2007 | 01:17 PM
thedilleyo's Avatar
So if I do go aftermarket (AVIC-D3) can I change out my factor Sirius box in the trunk with a XM box?
Old Jul 10, 2007 | 01:34 PM
Gilley's Avatar
You will need an XM box for the AVIC. The OEM XM box won't work with the AVIC and likely costs more anyway.
Old Jul 11, 2007 | 12:40 AM
thedilleyo's Avatar
Can I use the existing wiring that's running to the factory HU for the AVIC?
Old Jul 11, 2007 | 10:10 AM
Gilley's Avatar
No.
If you install any aftermarket HU, you'll need an XM box specific to that unit and you'll have to mount it somewhere and run wiring from it to the new HU. The only part of the OEM harness that you will/can use are the two harness plugs for power/ground and speaker outputs.
some aftermarket HU's are compatible with the XM traffic service. For certain HU's, there is also an XM traffic module that you can use even if you have Sirius, if the HU is compatible with it. It interfaces with the navi system.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
alessandro
Oct 8, 2015 09:29 AM
doakley92
Sep 25, 2015 12:58 PM
