Upgrading Door Speakers!
Old Jul 25, 2007 | 10:33 PM
baylorsig's Avatar
Question Upgrading Door Speakers!
I am not much of an audio guru, so I need some help. I have a 10" sub as well as a dvd touchscreen headunit hooked up. I am looking to upgrade the current door speakers (non-bose).
I am having trouble finding the exact size of the speakers? Does anyone have recommendations of badass speakers to install that around the $100/pair (good quality and can bump without blowing)? Also, what size speakers should I be looking for, and what's the difference between regular speakers and component?
Old Jul 25, 2007 | 11:04 PM
Gilley's Avatar
The front door speakers are 6 1/2 inch component speakers (separate tweeter.) 6 3/4 inch speakers will probably fit too. ^ 1/2 inch speakers don't really bump much, no matter waht brand. That's what the sub is for. You should also get a pair of MDF spacers for the door speakers to space them out from the door.
Old Jul 26, 2007 | 01:52 PM
jtrudeau's Avatar
To me, the speakers that get you the most bang for the buck are the Infiniti Kappa Perfect 6.1. With the MDF ring and dynomating the door, the play very well and are relatively inexpensive on eBay. It is also something that is very very easy to install yourself. There are plenty of DIY for speaker installations on this board. Just keep in mind what sounds great from someone else may sound like crap to you. Every speaker sounds different in every car.
Old Jul 26, 2007 | 01:54 PM
jtrudeau's Avatar
If you are using stock non bose stereo, search around to find the OHM rating of that unit. I know the bose was 2ohms, not sure what the non bose is.
Old Jul 26, 2007 | 03:02 PM
Gilley's Avatar
Non-Bose speakers are 4 ohm.
Old Jul 27, 2007 | 02:01 PM
baylorsig's Avatar
http://www.buy.com/prod/pioneer-ts-a...203922232.html
so will these work? anyone know about these? suggestions?
Old Jul 27, 2007 | 02:02 PM
baylorsig's Avatar
btw, what does it mean by , 4 way or 3way or 2way speakers?
Old Jul 27, 2007 | 03:30 PM
Gilley's Avatar
Those are coaxial (or coax) speakers and will work for the rear side panels, but you need component speakers (also called separates) for the front door.
These are component speakers that will work in the front doors.
http://www.crutchfield.com/S-VTryxlb...00&I=107DB6500
Old Jul 27, 2007 | 04:02 PM
05BLACK6MT's Avatar
it means you have 4/3/or 2 speakers build into one.
lets say a 3 way will have one for low, one for mid, one for high sound.
Old Jul 27, 2007 | 04:52 PM
baylorsig's Avatar
I am having a hard time understanding the difference between a 500/1 amp and a 500/5 amp.
I have a JL audio 500/5 amp, with a Kenwood DDX7015 headunit, memphis audio 10" sub and stock door speakers hooked up to it. I am planning on upgrading the door speakers, will the amp have enough power?
What exactly does 500/5 mean? DOes that mean it only has 100watts for each component hooked up to it? As in, the max power my sub is getting is 100watts, or can you divide the power to each component separately (sub gets 300, headunit 100, each speaker 50 --example)?
Old Jul 27, 2007 | 06:30 PM
jtrudeau's Avatar
Here is a link to the Manual for your amp.
http://mobile.jlaudio.com/pdfs/7208.pdf
According to the specs in the manual, you should have plenty of power for the front speakers.
I've taken the advice of a lot of people on this board and ditched the rear speakers when listening to music. The only time I use the rear speakers is when I am watching a movie.
Old Jul 28, 2007 | 10:18 AM
Gilley's Avatar
The 500/1 in a one channel amp rated at 500 watts. The 500/5 is a 5 channel amp that is 500 watts spread out between the 5 channels, but not equally.
Rated Power Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
The 500/5 is fine if you upgrade the door and side speakers, if you go with rear speakers.
NailBomb
Oct 28, 2015 07:53 AM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
