Slim PS2 glove box Q's
Originally Posted by MoHaWk2003
i didnt not tape mine down as its a tight fit in the lower glove box.
i can change discs without a problem while driving.
i have a big hole in mine so i can push the ps2 back far enough so i can shut it with the controller still connected. however you can not shut it with the memory card still connected. with out some dremeling to the front of the glove box and i still dont think it will work correctly. if anyone has found a shorty memory card, if you have found a way to remount the memory card, or has drememled the front of the glove box to make it fit please let me know. or post where you got it from or pics please
Originally Posted by QuadCam
any skipping problems with the DVDs while driving? what are you guys using to power it? does anyone make a car (12V) adapter for the PS2? or do you need an invertor?
my friend played gt3 and gt4 all the way up to ZDayZ from tampa a good 10 hour trip. no problems at all.
on
I have composite A/V inputs on the back of my Eclipse AVN5435 head unit. So I'm just running the PS2 A/V into that.
As for power I used the information found on these two threads to figure out what I need to do:
https://g35driver.com/forums/g35-coupe-v35-2003-07/96510-help-running-power-wire-battery-back.html
https://g35driver.com/forums/audio-video-electronics/166571-cigrarette-lighter-wiring-inverter-q-s-my-ps2-install.html
Originally Posted by SILVERSURFERG35
How are you getting sound from and power to the PS2 ? Any answers would be very helpful !! My shop was having a hard time with the install today !!!!
sound i just run it straight to the back of my ddx 7015 from the playstation
do you have a stock radio? if your shop does not know how tog et sound from the ps2 then they need to stop what their doing, and start with something a little more simple......
you need to get an audio unit that adapts to the stock radio (a pac unit is what i used in mine), or if you have a aftermarket radio im sure it just plugs in somewhere.
I think we resolved the two issues that we came across ! My shop is going to order me a pac unit for my stock radio ! I am going to us the sat button on the radio . I don't have satellite radio so I will be able to use that for better audio and not this crappy FM mod. Now the issue is a blue tint on all of the peoples faces and some objects . I have spoken to like three people and they think I got a bad TV/Nav box unit ! Other than that the picture is very clear ! Thanks for all of the input folks !!!
