Airbag/SRS light flashing
Old Aug 20, 2007 | 10:54 AM
shdowflare's Avatar
Hey guys,
I installed an inverter and PS2 into my G yesterday and that's working great. However, I now have a flashing airbag/SRS light on my dash. Anyone have any clues what may have gone wrong?
I did drill into the back of the OEM DVD compartment. I also took out the front seat bolts and was moving the seat using the power controls while it wasn't fully secured to the floor. And of course I ran 10g power cable in from the battery, then split it between the passenger cig lighter and inverter.
I guess I'll have to retrace my work but I figured I'd ask if anyone knows whether anything I did yesterday that would definitely throw off the airbag/SRS circuits.
Thanks,
B
Old Aug 21, 2007 | 02:03 PM
shdowflare's Avatar
I thought about doing the ECU reset procedure to see if that clears up the condition. I figure if it the error light is flashing again after the reset there's definitely a problem, but if it clears up then maybe a sensor was thrown off while I was cutting/restoring/testing the 12v power line several times during the electrical work this weekend.
If I reset the ECU, is there anything I should know or be concerned about? Can you guys think of a reason not to do an ECU reset as part of troubleshooting?
Thanks,
Brian
Old Aug 21, 2007 | 04:27 PM
Gilley's Avatar
Resetting the ECU won't hurt anything.
There is also a procedure to turn off the airbag light somewhere. It's pretty easy and involves switching the ignition key on and off in a certain sequence.
Old Aug 21, 2007 | 04:42 PM
shdowflare's Avatar
So it sounds like the reset won't change my reflash...
As for just disabling the flashing SRS light, shouldn't I try to figure out what's wrong if it continues to flash after the reset? Or is it just a nuisance which poses no real threat?
Thanks,
B
Old Aug 21, 2007 | 04:53 PM
Og_Dave's Avatar
to turn off the airbag light i believe you had to turn the car to the "ON" mode , "thats before you start up the car" and do it several times . example is to turn it ON for like 4 secs then turn the key all the way off and it it again 2 or 3 times and the light should go away.
i had that airbag problem and thats how i turned it off, but for me my airbag sensor was actually bad and had to get a new airbag put it.
Edit.https://g35driver.com/forums/showthr...t=Airbag+light
theres the link to do it haha
Old Aug 21, 2007 | 08:18 PM
Gilley's Avatar
Yes, you should see what is causing the light to trigger.
Old Aug 22, 2007 | 02:02 AM
shdowflare's Avatar
Alright I'll check into it if it's still flashing after the ECU reset. Thanks guys.
Luisgalvan33
Jul 19, 2018 08:16 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
flytim3
Sep 5, 2015 01:23 PM
ghost_g35
Aug 7, 2015 10:31 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
