Amp overheating?
Old Aug 21, 2007 | 01:27 PM
brazil0525's Avatar
Amp overheating?
All the connections are fine, im runnin 1 amp with 1 12" sub, but after about 10 min, the sub shuts off. Ill go and check out the amp, and its led will be red (instead of green) and its BURNING hot. Not to mention the temp down here in miami was about 100 degrees. If i turn the car off for a while and turn it back on, same thing happens
Could this be why my amp shuts on and off?
Would buying a fan help?
Old Aug 21, 2007 | 01:30 PM
05BLACK6MT's Avatar
what's the rating for the amp and the sub ? Location of the amp? What gauge wire for the amp? and such.....
Old Aug 21, 2007 | 02:16 PM
brazil0525's Avatar
sorry bro, dont kno those specs. BUT i went to one of the more reputable shops here and they suggested the sub that i got, and also suggested me to use an 8gauge amp kit. The amp is a sony xplod 1000 and the sub is a 12" kicker. The amps in the trunk. I can prob take a look at the sticker and see if it gives me any of that info
thnx
Old Aug 21, 2007 | 04:25 PM
Gilley's Avatar
you probably have the wrong impedance load for the amp. If your sub has dual voice coils and you wire them in parallel, your amp may not be able to work with such a low load. The amp will get hot and trip the thermal or short circuit protection.
Old Aug 21, 2007 | 05:31 PM
brazil0525's Avatar
Thanx...hey im not sure what all that means (im more fo an engine person, when it comes to audio, im pretty lost) How would i fix this?
Old Aug 21, 2007 | 05:59 PM
bb996+r1's Avatar
What guage wire are you using?
Old Aug 21, 2007 | 10:51 PM
Meatshackle's Avatar
Deep Sea Moderator
8awg on a 1000 is not enough.
Also, how is it mounted? Vertically? Horizontally? In an enclosed space?
Old Aug 24, 2007 | 09:31 AM
ron4row2's Avatar
Also, make sure that the gain is not turned all the way up and depending where you have it mounted i.e. if it's on the floor board or under a seat it will usually run much hotter.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
