Auto Ac On! Radio Lights Off!! No Buttons Work
Old Sep 28, 2007 | 07:31 PM
Kensi's Avatar
Omg.. iono wtf.. it just started happening to me.. The radio display is no showing, also my AC is constantly on and i cant do anything about it. Apparently no buttons are working, except for my steering wheel i can still change tracks... I did do a search however it doesnt really help. I dont knwo what i can do now since i have no more warrently left. anyone help please?
Old Sep 28, 2007 | 08:11 PM
Beebo's Avatar
i guess just pay up at the dealer
Old Sep 28, 2007 | 08:27 PM
zackt69's Avatar
rarejdm.com
Check your fuses... both inside by the pedals and in the engine compartment by the battery. Same thing happened to me (plus my blinkers stopped making the blinking noise), ended up being a fuse.
Old Dec 24, 2007 | 06:38 PM
dilated777's Avatar
I am having the same problem- radio only works on the steering wheel and A/C is stuck on Auto. Not sure if it has anything to do with eachother but the navi screen started blinking for a while and then this problem happens. There were some times where everything would come back on when I jimmied with the navi by putting it down and up a couple of times but that trick doesnt seem to working anymore. Any suggestions are appreciated.
Old Dec 24, 2007 | 07:27 PM
jd2k1's Avatar
Same thing happened to me. It was a blown fuse.
Old Dec 24, 2007 | 07:36 PM
O HELLA OEM's Avatar
time 2 go 2 the stealership
Old Dec 24, 2007 | 07:39 PM
2drwild's Avatar
Same thing happened to me and it was the control module above the stereo. It was covered under warranty. It just sucked because it went out during a long cruise.
Old Dec 25, 2007 | 09:17 AM
03Sg35's Avatar
its the Radio/ac control circuit board, I think Infiniti has a recall on this item but you have to run your VIN to see if you are affected by the recall. Or just buy a used radio in marketlace, DO NOT go to the dealership if you have no warrenty, cost 400-600 installed, used radio 250. Check infinitihelp.com abouthe recall"AC/radio ciruit board" gl
Old Dec 25, 2007 | 01:44 PM
dilated777's Avatar
Not the fuses. Going to check that site to see if I am affected by the recall. When you say buy a used radio...do you mean a OEM bose? If so, do I have to go to the dealership to get it installed? Thanks for the help guys! I knew I would be able to find the right advice on this board.
Old Dec 25, 2007 | 01:59 PM
dilated777's Avatar
Here is what I found on Infinitihelp.com
VOLUNTARY SERVICE CAMPAIGN 2003 INFINITI G35 SEDAN; AUDIO FINISHER CIRCUIT BOARD
On some model year 2003 G35 Sedans manufactured through August 21, 2002, the audio and temperature controls may not operate as expected. When using the audio equipment or the temperature controls, the unit may become inoperative. In some cases, this can be corrected by turning the ignition switch off and back on again. In other cases, the unit remains inoperative and requires service by an Infiniti technician. To prevent this condition, Infiniti has initiated a Voluntary Service Campaign to replace the audio finisher circuit board on these vehicles. Use Infiniti Net to confirm if a specific vehicle is affected by this service campaign (P3104).
My question is- What is Infiniti Net? cant seem to find where to check my VIN
Old Dec 26, 2007 | 07:53 AM
03Sg35's Avatar
Yes oem Bose unit, lots of people go with Double Din aftermarket units and sell the oem ones, check the marketplace "All star gene" is selling his right now. You can install it yourself plenty of DIYs on here, or use a shop not the dealer unless you have $$$ ready. dont know ifiniti net so GL
Old Jan 3, 2008 | 11:25 PM
BurntRenolds's Avatar
I'm going to pull out my circuit board and see if I can manage a DIY...
Old Jan 23, 2008 | 01:58 PM
bradster's Avatar
Burnt, any luck w/ the board or radio?
Old Jan 27, 2008 | 01:08 PM
RiCeBrNr's Avatar
I just got the same problem any updates on your end?
Old Jan 27, 2008 | 03:59 PM
RiCeBrNr's Avatar
Can someone also tell me where exactly this part is located? Is it part of the HU or trim?
A picture would be good if someone has it and maybe a part #?
Thanks guys!
