Help with PAC-SWIPS wiring connection
Old Oct 1, 2007 | 12:41 AM
thinhdle's Avatar
Question Help with PAC-SWIPS wiring connection
Hi all:
I need some clarification here:
2. Connect a 150 ohm resistor to pin 23(green). Connect a 47 ohm resistor to pin 22(red). Connect remaining ends of resistors to the INTERFACE's white wire. Connect pin 25(yellow) to chassis ground.
Does this mean both resistors are connected to the interface's white wire???
Is this normal???
Old Oct 1, 2007 | 09:47 AM
Gilley's Avatar
Yes, both of the resistors connect to the white wire, like a Y. I added a short piece of wire to the other end of each resistor (the end not attached to the green or red wire) and connected both of those short ends to the white wire.
Old Oct 1, 2007 | 10:12 AM
thinhdle's Avatar
Thank you
I'll do the same. Did you solder the resistor to the wire or other method?
Old Oct 1, 2007 | 12:22 PM
Gilley's Avatar
Butt connectors.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
