Pushbutton start in an '04 Coupe!
Old 10-28-2007, 06:54 PM
SFLG35's Avatar
FGC President
Originally Posted by 2K6G35
Found this DIY thread about putting the push button start on VW Touareg with a keyless entry system. It does not look too complicated to install.
It looks amazing!
yeh doesnt look to bad but that is a pretty involved process, especially the taking apart of the connector. with a good diy though tough installs become much easier and less time
  #62
Old 11-19-2007, 11:07 PM
frog's Avatar
Originally Posted by hai109
Well, with most push button start system its the same thing...Hondas, Nissan, etc...Same for Mclaren. The more advance push button uses the intelligent key but the problem with that system is if the battery dies or your cell phones messes up the signal you have no way to start your car.
the lexus's have 1 key hole which is the door, if the battery dies u just get your key fob and put it next to the start button and press the button and wala it works. u can do that till u replace the battery in your key fob.
btw. i like the idea of the push button start but i dont like the idea u have to get the key out of your pocket and turn it then press button. personally i would rather have a setup where i wont have to take out my key just press the button to start and go vroom.
  #63
Old 11-20-2007, 04:29 PM
ShadowG35's Avatar
I'd like to have this, but I can't find a good place to mount it in my '05 coupe
  #64
Old 01-19-2008, 08:41 PM
chester's Avatar
any new updates on this? or a really detailed DIY?
  #65
Old 01-20-2008, 12:32 AM
04G35NYC's Avatar
looks clean, i like it alot.
  #66
Old 01-20-2008, 12:49 AM
KPierson's Avatar
The module has been successfully beta tested and was about to go on sale when I decided to make some major changes to it.
The new version isn't quite done yet, but it won't require you to hold the 'START' button down to crank the car. You will step on the break, push and release the button, and the car will start.
  #67
Old 01-20-2008, 11:25 AM
TheDude's Avatar
any updates on the push button start I heard it was supposed to be released really soon..
  #68
Old 01-20-2008, 11:51 AM
lowrider's Avatar
Still waiting
BTW -
Break - separate or cause to separate into pieces as a result of a blow, shock, or strain.
Brake - device for slowing or stopping a moving vehicle, typically by applying pressure to the wheels.
Lou
  #69
Old 01-21-2008, 11:07 PM
KPierson's Avatar
Doh! I'm usually pretty good at spelling it correctly.
Hopefully I'll have some new videos up this week of the new version of the module working in my test car.
  #70
Old 01-22-2008, 09:59 PM
dumaG35's Avatar
Very interested in this. Question- Anyway u can delete starting the car using the key. I think if i put the key in and turned it all the way it shouldnt be able to start. Push button is pimp though. Let me know some new info and pricing.
-TJ
  #71
Old 01-23-2008, 06:21 AM
KPierson's Avatar
Yes, you can cut the starter wire so that the key will no longer start the car.
  #72
Old 01-23-2008, 11:46 AM
Sportcoupe35's Avatar
So still no intention of making this to replace the "turn ****" for the newer Gs with the Intelligent Key?
It would be ideal just to remove the "turn ****" and install this button and have everything functioning the same way. I don't think it would be that difficult...in theory at least hahahaha but I'm not very good with electronics and stuff.
  #73
Old 01-23-2008, 11:51 AM
KPierson's Avatar
I still haven't seen the turn **** you are talking about. I have no intentions of coming up with a custom solution for that specific vehicle, but like I've told you before there is a good chance that this will work with your setup.
  #74
Old 02-25-2008, 09:35 PM
KPierson's Avatar
Here's an update!
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/-I6XAj0AQWA"> </param> <embed src="http://www.youtube.com/v/-I6XAj0AQWA" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Push button start without holding the button down - push and release and the car starts itself!
  #75
Old 02-25-2008, 09:50 PM
O HELLA OEM's Avatar
Quick Reply: Pushbutton start in an '04 Coupe!
