2003 Window Problem
Old Oct 16, 2007 | 04:05 PM
StlCreepin's Avatar
2003 Window Problem
Hi there, In my 2003 Coupe my windows wont roll up after you shut the door, I have check my fuses and found a blown fuse and replaced it but it started doing it again, so I checked the fuses again and found nothing, also my dome lights wont work. Is there a certain fuse I need to check because I didnt see one labeled for these specific things. Any help would be appreciated, This all started I think after i got a jump. Thanks
Old Oct 17, 2007 | 05:45 PM
KPierson's Avatar
These cars are notorious for window motor/regulator failures. The dome light fuse should be in the kick panel by your feet. I don't believe it is labeled the way it should be, to make it simple to find.
Old Sep 17, 2009 | 02:07 PM
mrsc's Avatar
I have pretty much the exact same behavior as you had, after a jump, I have intermittently working windows, and my dome light didn't work. After I disconnected the battery the dome lights started working again (no fuse change) and the windows went back to intermittent. I've read a lot about the window motors on the G's but in my case both windows don't work and also the power lock on the driver door doesn't work at the same time...is this what you see when you have a bad window motor because if I didn't know any better it sounds more like some sort of electrical issue like a relay or ???? Did you ever figure your problem out?
Thanks
leo38cheng
Nov 12, 2015 06:49 PM
Tyler's03G
Aug 13, 2015 10:04 AM
chinee
Aug 8, 2015 10:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
realtalk21
Jul 20, 2015 09:07 AM
