ZEnclosures?
Old Nov 7, 2007 | 05:04 PM
SIR NUPE A LOT's Avatar
ZEnclosures?
Does anyone have any experience with these sub boxes from this EBay seller? I need a new custom box build for the G, because the slot port box I had in my last car won't work! I was hoping to go with another slot port box setup, but I found this instead.
http://cgi.ebay.com/ebaymotors/Infin...ayphotohosting
Old Nov 7, 2007 | 05:26 PM
1trueG's Avatar
I've read that theyre decent, but that the boxes dont produce the best bass/sound.
Old Nov 7, 2007 | 05:42 PM
^That is my main concern! The last time I bought an off the shelf box, my subs sounded like crap. I then had to get someone to make me a custom slot port box, and the difference was night/day! I won't sacrifice looks, for sound.
Old Nov 7, 2007 | 06:03 PM
Gilley's Avatar
Mike, the owner and fabricator of Zenclosures, can make the box to suit your speaker requirements. Call him and let him know the specs of your sub(s) and he will take care of you. His boxes are of good quality.
Old Nov 7, 2007 | 06:35 PM
Rocket1991's Avatar
A lot of people here use those boxes, but the main problem with the Zenclosure setup is that its a single chamber that is about .8 cu. That is way too small for most subs, even shallow mount ones. you can put a divider in there, but that cuts the space into 0.35cu, and you won't find a decent sub that would sound good in that kind of space.
I had the same problem with my setup and even though it was my last choice, i am now buying 4080 enclosures for the drive and passenger side. In my last ride, a '00 Maxima, i spent the same amount on my entire setup as i am spending on just the enclosures and the subs to go in them. if you want to install a decent sub and not loose too much trunk space the only way to go is a 4080 box. or, you could always have a shop make you a Zenclosure type box that is a bit larger.
Good Luck
Old Nov 7, 2007 | 09:09 PM
sjc1789's Avatar
Florida G35 Club
i have one and love it. looks real clean. perfect fit. easy buy too. good guy to buy from. get compliments all the time.
Old Nov 7, 2007 | 09:18 PM
scarface_613's Avatar
i can vouche for him i have a 12" w3 and it sounds really good, just give him a call if your not sure bout something, but as far as the quality i give it an A+++
Old Nov 7, 2007 | 09:21 PM
06g35meister's Avatar
on OEM head unit?
Old Nov 7, 2007 | 09:53 PM
kernel's Avatar
SEC > Big 12
I'm also in a similar boat. The zenclosures are very tempting for the price, but between SQ and space, I'm really thinking 2 4080's are the way to go. The difference is $600 in price tho, which is pretty significant considering that's more than my subs and amp may cost.
Old Nov 7, 2007 | 11:11 PM
ill_ace's Avatar
if you really want a zenclosure then just buy a sub that will perform well with those specs. From my experiences with zenclosure they make quality products. You just need to make sure that they suit your applications. Any sub cant just be put in any box.
Old Nov 7, 2007 | 11:18 PM
yes
Originally Posted by 06g35meister
on OEM head unit?
Old Nov 8, 2007 | 10:10 AM
TIGHT! Thanks Gilley, I will call him!
Old Nov 8, 2007 | 10:15 AM
I already have my subs, two 10" Kappa Perfect 10.1D subs. The specs for the sub in a sealed box says 0.6 cubic feet.
Picture Share
Feb 4, 2018 12:41 PM
mpapers
Jul 25, 2016 04:23 PM
jaysonz35
Archived Sales
Jan 3, 2008 09:09 PM
NJlakeshoreG
Archived Sales
19
Nov 20, 2007 08:47 PM
