AVELECTRONIC instructions
Re: AVELECTRONIC instructions
What couldn't they provide you with?
I got instructions with mine, granted they were very basic and not too detailed. Do you have the unit?
Basically you need power, ground, splice your nav wires, install your "cop" button, hook up your source, connect your fm modulator wires, install antennas, and install your remote eye. I think that's about it.
If you're looking for more detail let me know.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Russ
Black 6MT Coupe
Jax, FL
I don't have a scanner but I have a pretty good digital camera. I'll try and get a decent pic. Like I said before they aren't too detailed. I didn't even use them.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
Hope this works.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
I can't remember but I think there is a wiring harness that you disconnect and then connect 2 seperate harnesses from the Av box into those 2.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
There's a couple of 4 wire harnesses. You have to cut a pink wire.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
hey trentacinque,
your av setup, do you have problem with color not being display properly? My friend have it and normally it takes about 5 to get the correct color. my friend call them up and they said that sometime it require about 5 minutes of warming up before the correct color display properly on the screen. Do you encounter similar problem? thanks.
g35mt
g35mt
Nope. No problems. I've never heard of that before.
Russ
Black 6MT Coupe
Jax, FL
Russ
Black 6MT Coupe
Jax, FL
my friend and i live in southern california. there are no snow, etc.
but the problem is not the screen rather is the av unit. we test it out by turning on the unit and use the navigation. the color and everyting seem fine. next we let the car sit for 30 minutes, then fire her up and starting using the av unit, picture display weird color for about 1 or more. then after about 2 or more minutes, the color is back to normal. i know so when looking at the rear monitor, it display green on the clothing while the front display show only white.
btw, my friend have the fx35.
trent didn't seem to have any problem. so i guess maybe it might be related to the fx only.
g35mt
g35mt
