Auto Climate Control Problems
Old Dec 26, 2007 | 05:16 PM
Trigonal's Avatar
I have an 03 Sedan with automatic climate control. Everything about the system seems to work fine, except for the temperature setpoint function. In the winter, the heat will always be on full heat, whether I have it set to manual or auto climate control. The only way to turn off the heat is to set the system to 60F (the lowest setting). In auto mode, I've had the temperature setpoint set at 61F and the fan goes to full speed pumping out heat. I've waited 20 minutes to see if the internal temperature would eventually rise and slow the fan or turn down the heat. It never happens, it felt like Miami in August inside the car before I finally shut it off.
My guess is that the interior temperature sensor must not be working??? Does anyone know where it's located and what to check for. (I'm guessing that it must have one in order for auto climate control to work)!
Stereo, CD player, navigation, defrost, and all other center console functions seem to work just fine.
Old Dec 26, 2007 | 05:48 PM
03Sg35's Avatar
Look at this it has the info you need and search some more for the future
https://g35driver.com/forums/audio-video-electronics/180189-auto-ac-radio-lights-off-no-buttons-work.html
Old Dec 26, 2007 | 10:53 PM
Trigonal's Avatar
Audio Finisher Circuit Board
Thanks, but I've already read all about this problem.
I haven't read about anyone else having a problem with only auto climate control. Everyone I read about had multiple problems with the radio and a/c controls. My radio and a/c buttons work fine. All the buttons work, it's just that the heat doesn't shut off once the interior is warm. Maybe related, but not convinced!
Is there a temperature sensor on the Audio Finisher Circuit Board?
Old Dec 27, 2007 | 07:30 AM
03Sg35's Avatar
take it to the dealer. I dont use the auto feature so dont know much about it but GL with it
Old Feb 9, 2008 | 07:26 PM
jtevis's Avatar
Same problem
I'm having the same problem as you on my '03 coupe. Did you find a solution. You can't just turn the auto off, cause the heat is on full unless you turn the temp to 60, then it's too chilly.
Old Feb 9, 2008 | 08:33 PM
Noremac's Avatar
This problem is being caused by a fault in the interior temp sensor. About 9 times out of ten it is simply due to a disconnected sensor. Look at the driver-side dash near where your right knee rests. There is a small grill air intake that covers the interior temp sensor. Behind the dash is an electrical connector to this sensor. Frequently, if anyone has worked under your dash area, this sensor gets disconnected for ease of access, and then gets missed at the end of the job.
Old Feb 10, 2008 | 01:33 PM
jtevis's Avatar
Thanks, the wire was disconnected. I've been trying to have a remote starter installed and the installer left it disconnected!!
Old Feb 11, 2008 | 01:18 PM
Trigonal's Avatar
Climate Control
It looks like you found the problem. I fixed mine as well by just plugging back in the electrical connector. But also look for the 1/2 inch hose that also connects . Both my electrical connector and the hose were disconnected. I wish all problems were such a simple fix!!
Old Feb 18, 2008 | 11:15 PM
slowek04's Avatar
sorry for bringing this back from the dead, but I'm having the same problem now and wanted to know if I install a double din kit, will it have the same problem? TIA
EDIT: OOPS NEVER MIND WHAT I WROTE....i thought i was on a different thread (had two separate pages open).
derres
Aug 28, 2015 03:27 PM
erickLA
Aug 18, 2015 04:46 AM
Phenomenon9
Aug 9, 2015 01:34 AM
attarday
Jul 15, 2015 04:03 PM
