Program Navigation While Moving DIY
Old Jul 10, 2004 | 08:05 PM
  #31
G352NV's Avatar
Never enough
Re: Program Navigation While Moving DIY
Just got done with this and wanted to say thanks for the write up! Very easy mod! Took about ten min.
Old Jul 14, 2004 | 12:56 PM
  #32
rieskame's Avatar
Im assuming you disconnected the battery before doing this mod?
Old Jul 14, 2004 | 01:37 PM
  #33
G352NV's Avatar
Never enough
Nope
Old Jul 14, 2004 | 03:58 PM
  #34
Meatshackle's Avatar
Deep Sea Moderator
There's no need to disconnect the battery if you don't disconnect the yellow airbag wire harness.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 14, 2004 | 08:52 PM
  #35
SoCalTed's Avatar
here's my setup...
left side is master switch for all my aftermarket goodies (AVelectronics nav/tuner, PS2, BearCat tracker, rear DVDs, power inverter, and trunk mounted power block)
Second switch is my NAV VSS hack, to allow input while driving.
Third is the toggle switch for the nav/tuner.
Cheers, Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Jul 15, 2004 | 02:21 PM
  #36
Drewer's Avatar
Wow, this shows how observent I am! :-P What is the switch in the glove box for? I've never seen it. Better go check now!
-drew-
Old Jul 15, 2004 | 02:26 PM
  #37
SoCalTed's Avatar
that's the switch to turn off your trunk switch so they can't open it from the driver side.
Switch it to OFF, lock your glove box and give them the valet key... no access to the trunk.
-T
Old Jul 15, 2004 | 03:27 PM
  #38
Drewer's Avatar
Cool. Thanks for the info! So does this mod remove it's functionallity all together?
-drew-
Old Jul 15, 2004 | 05:24 PM
  #39
SoCalTed's Avatar
not sure... I would not imagine so, if you splice it in. Although, I used a separate rocker switch.
-T
Old Jul 15, 2004 | 06:06 PM
  #40
Deep Sea Moderator
Yes it no longer allows you to lock your trunk. You have to connect the original wires for the trunk together or your trunk will be permanently locked.
Russ
Black 6MT Coupe
Jax, FL
Old Jul 16, 2004 | 11:25 PM
  #41
augie's Avatar
How much spend for your nav to dvd setup ted? where in so-cal you get it done at?
Old Jul 17, 2004 | 12:04 AM
  #42
Drewer's Avatar
Right on. . .I'm using a seperate rocker switch then.
Thx!
drew
Old Sep 2, 2004 | 02:27 AM
  #43
spike's Avatar
Couldn't you just splice the 2 new wires together with the existing wires of the trunk switch so that both remain operational?
Old Dec 28, 2004 | 05:31 PM
  #44
UncleCemka's Avatar
Unhappy 2005 Navi Mod
I just tried to do this mod on my brand new 2005 G35X, and I don't think that the wires are the same for this model year. I spliced into the green and the white wires, and when I flip the switch, the Navi colors get all screwed up. I had to put everything back together, and thank god it still works right!!! Can someone please confirm which wires need to be spliced for the 2005 G35, and from which harness. I am not putting the glove box back on yet, and would like to get this done. Please let me know.
Thanks,
Sam
Old Dec 28, 2004 | 05:53 PM
  #45
symalik's Avatar
that sucks, i was gonna do this the very first day! i guess some one needs to get the diagrams for the 05's to confirm
