speakers/amp
Old Jan 3, 2008 | 06:28 PM
jon.cole's Avatar
speakers/amp
Im looking for a set of speakers and i think im between infinity kappas/mb quarts or diamond audios... I am planning on replacing my stock headunit with a kenwood 8019 and i plan on replacing the stock amp too... What amp should i get if i plan on adding on a 10w6 later? Do i need spacers if i am replacing the amp? How easy will it be to have to car returned to stock for trade in?
Thanks,
Jon
Old Jan 4, 2008 | 11:01 PM
jon.cole's Avatar
bump anyone?
Old Jan 5, 2008 | 01:11 AM
PoorG35's Avatar
its not worth changing it back to stock in my opinion.
it depends on who installs it and how they do the bose amp bypass if you can even put it back to stock.
if i got a w6 id get a 500/1 jl amp. id also probably get a 4chan amp too. you could buy both matching amps around 500-600 used for both.
id buy kappas. or focal 165v2
Old Jan 5, 2008 | 01:35 AM
jon.cole's Avatar
so i did a little bit more research and this is what I think i am going to do...
Front - MB Quart PVF 216 Components
Back - MB Quart DKG 116
Back Deck - MB Quart DTG 169
Amp - JL 500/5
SUB - 10v6
(being biast to the front of course)
Do i have enough power?
Old Jan 5, 2008 | 02:38 AM
TheTick's Avatar
I've been doing a ton of research trying to find the right components on a budget. Everyone on this forum seems to like the kappa's for the price.
The guys over at the car audio forums are all raving about the pheonix gold rsd's that only cost $87. Some say they are on par with $400+ comps and all of them seem to agree that nothing under $250 beats them. So I ordered a pair.
Here's a couple links:
http://www.caraudio.com/forum/showthread.php?t=281142
http://www.caraudio.com/forum/showthread.php?t=277618
http://www.caraudio.com/forum/showthread.php?t=282038
Old Jan 5, 2008 | 03:00 AM
TheTick's Avatar
As for amps, Jl is hugely popular but alot of the guys in the car audio forums say they are overpriced. Kicker seems to be a popular choice.
I also noticed that alot of these guys are running 120-150 watts to each component. The pg 6.5 rsd's are only rated at 60 watts but people are running at over twice that and love it. The advice they gave me was to forget about the rear and focus all the power up front. I was originally gonna run 60 watts to all four off a 4ch amp, but now I'm gonna bridge it and do 120 up front and run the rears off the head unit. This is supposedly the ticket, I'll find out soon.
Old Jan 5, 2008 | 04:58 AM
PoorG35's Avatar
no the 500/5 is not enough power for the w6 at all. bad idea.
dont worry about the rear deck lid 6x9s
Old Jan 5, 2008 | 05:28 PM
Gilley's Avatar
Amp - JL 500/5
SUB - 10v6
IMO, you don't need to install speakers in the rear sides and the rear deck. One or the other, but both is overkill. The rear is only for fill anyway.
A JL 500/5 works fine with front components, rear side coaxials, and a 10w6 in a 4080 enclosure. I had that combination for about a year and it was plenty of bass, despite being a little underpowered on paper.
Old Jan 5, 2008 | 07:33 PM
jon.cole's Avatar
thanks Gilley that was a lot of help do you suggest I remove the 6 x 9's and leave them as holes for more bass? Or is it not worth the pain to do... How does everyone like mb quart though?
Old Jan 5, 2008 | 07:59 PM
TheTick's Avatar
You'll probably get alot more info in the car audio forums. Let us know what you find out.
dlim
May 7, 2013 12:49 PM
jsm11482
Car PC
Oct 14, 2012 09:56 PM
AuAltima3.5
Oct 27, 2011 12:26 PM
JVSavarese
Dec 26, 2010 03:44 AM
cashsmoney
Nov 22, 2010 01:34 AM
