Alarm question
Old Feb 13, 2008 | 01:24 AM
Petoria's Avatar
Alarm question
Ok, i have an 06 coupe 5AT with the premium pkg/Intelli key. I want to upgrade the alarm system b/c it doesnt do anything if someone breaks in. Thing is, i want to keep the intelli key features and be able to walk up and leave the fob in my pocket. What alarm system out there will let me do this? I dont mind having another fob/pager in my pocket...just as long as the intelli key works.
Any suggestions? and if anyone has this kind of set up lemme know
Old Feb 13, 2008 | 12:06 PM
bngu1's Avatar
you can get the Viper 330V it is design to fully integrate with OEM alarm systems. it is arm when the car is locked and disarm when the car is unlocked
Old Feb 13, 2008 | 12:11 PM
Hi-TechG35's Avatar
Compustar Ftmw!
Old Feb 13, 2008 | 03:09 PM
Petoria's Avatar
thanks bngu1 ill look into that
which compustar?
Old Feb 14, 2008 | 10:43 PM
SiouxFallsG35's Avatar
+2 for Compustar. I have the 2W900FM in our '04 Maxima and like it so much that it's also in my Eclipse GTS. I've owned several DEI products in the past (DEI ownes almost all the other brands - Viper, Python, Clifford, several others) and they just don't compare. Compustar range is phenominal and they have numerous models to choose from. The 2WSS models have the longest range although I'm impressed enough with what I have.
Your installer will likely use a bypass module from DEI even if they install a Compustar alarm. DEI and others have recently introduced nissan/infiniti modules that don't require consuming a key, or in your case an I-Key. Not a bad idea to ask for a nissan specific bypass considering the cost of extra keys, even through ebay. I used a standard bypass on both cars which required consuming keys that I bought through ebay and programmed at the dealer.
Old Feb 15, 2008 | 02:35 AM
Petoria's Avatar
what does consuming keys mean? i can keep my intelli key fob? or use a compustar pager thing and that will work like the intelli key where it can stay in my pocket?
Old Feb 15, 2008 | 08:02 PM
bngu1's Avatar
basically all aftermarket alarm will work with the intelli key. if you just want to use your intelli key but wanted more protection then get the viper 330v. if you don't mind having to carry another remote in your pocket then get a 2-way system, for which it will page you if the alarm is set off. FYI, if you get an alarm that has it's own remote, you will have to hit unlock on that remote before opening the doors or else you set off the alarm. i think the viper 330v is a better choice if you have the intelli key. will still work lock/unlock automatically on it's own.
Old Feb 15, 2008 | 08:51 PM
OP - Sorry, after re-reading your original post, I realized that I went off in a direction that you weren't even asking about. Remote start/security systems typically have to consume a key in a hidden bypass box order to fake the car into thinking a real key started it. You were asking about security rather than remote start security systems.
Old Feb 17, 2008 | 01:19 AM
KPierson's Avatar
If the door is opened while the alarm is armed the OEM alarm will go off.
You can add single stage sensors fairly easily to the OEM alarm, and do a few other 'cheap' things to make the OEM system a bit more secure. You may want to investigate this option before you drop the cash on a full featured alarm.
Old Feb 17, 2008 | 02:33 AM
Petoria's Avatar
so i can just add sensors to the OEM alarm? where can i get a hold of these sensors or w/e and what other "cheap" things are you talking about? would be better if i could do this and not spend more on a full alarm
Old Feb 17, 2008 | 11:12 AM
KPierson's Avatar
You can add single stage sensors by wiring them in with your hood pin. When the sensor is triggered it will make the car think the hood has been opened, so the alarm will go off.
Then, take a look at this: https://g35driver.com/forums/audio-video-electronics/136819-oem-security-system-upgrade.html This is the quickest way to improve the effectiveness of the OEM alarm system.
Old Feb 17, 2008 | 03:09 PM
Petoria's Avatar
hrmm..ok imma look into this
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
