Alrarm sound
Old Feb 26, 2008 | 07:42 PM
vash_g35's Avatar
Alrarm sound
Hi
Just wonderin if theres' a way to make chirp sound different (when locking/unlocking the car). Instead of the horn that sounds "poot-poot", I want it "beep-beep" like a digital sound, like the ones they use for benz, beamers, lexus and other luxury cars. Is there a thingy that needs to install, replace, etc?
Old Feb 26, 2008 | 07:56 PM
O HELLA OEM's Avatar
http://kptechnologies.com/
Old Feb 26, 2008 | 07:57 PM
^click products then electronic beep =]
Old Feb 26, 2008 | 08:07 PM
vash_g35's Avatar
cool! thanks man! problem solved
Old Feb 26, 2008 | 09:03 PM
Capitol G35's Avatar
How do you hook that up by the way?
Old Feb 26, 2008 | 09:12 PM
vash_g35's Avatar
i checked out the installation guide and it looked complicated to me,. but i will look for the car's repair manual, maybe it will help to look for the right wires.
Old Feb 29, 2008 | 07:07 PM
KPierson's Avatar
If you are familar with vehicle wiring it is one of our easier modules to install.
You need to tap the door lock actuator, door unlock actuator, ground, constant power, and switched power. The only difficult part is running the beeper through the firewall and under the hood.
Old Feb 29, 2008 | 07:11 PM
vash_g35's Avatar
Am not a techy guy, so Im gonna have a problem looking for these wires in my car. If there's a DIY with a piture walkthru, that would be awesome
Old Mar 3, 2008 | 02:36 PM
KPierson's Avatar
DIY with picture walk throughs don't work too well with this car. The wiring is right at the BCM and there are multiple wires of the same color there, so you can't simply go on wire color. This is a module that you must relay on a volt meter to install correctly!
Old Mar 4, 2008 | 02:03 AM
vash_g35's Avatar
eeek! sounds scary! LOL! Any shop that you suggest to install it? I may not be able to install this.
Old Mar 4, 2008 | 10:49 AM
KPierson's Avatar
You would be best off asking someone in a local forum to recomend a local shop. An alarm shop shouldn't have any issues installing this!
Old Mar 4, 2008 | 11:38 AM
vash_g35's Avatar
ok, thanks!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
