Tried to search, nothing came up. What are you guys with this setup doing. Just throw that sub on and call it a day or are you adding some polyfill?
Thanks,
Thanks,
the 4080 box is actually slightly larger than JL specs for a sealed enclosure so no polyfill is needed. If anything you should add some sound deadening to the inside to displace some of the volume and add mass dampening for better response
Quote:
Let me know how it sounds, I'm looking to do the same setup. What amp are you running with the 10w6v2?Originally Posted by tjlazer
ok thanks!!!
