Highly recommend the Valentine 1
#78
Originally Posted by jimmyc13
I understand that the V1 is a favorite here, and others have mentioned it's so great because it tells you which direction the threat is coming from, which is cool, but does it TRULY matter "where" the threat is coming from? I mean, don't you want to slow down anyways? Just curious.
In a city environment where you frequently have police in neighborhoods the indicators can tell you what road to expect the cop on, etc. by using the arrows AND the signal strength.
It's really quite amazing and until you've used one with the arrows for awhile you really won't fully understand.
That is, of course, just my opinion.
#79
any radar behind you will also bounce off of the person in front of you, and go into your detector.
After using a detector for years, I can tell if the cop is coming from behind with his radar on, up the road parked, etc etc....
My $.02
The V1 has, by far, the best marketing of any detector on the market.
My $.02
#80
My $.02
My $.02
#81
Originally Posted by Virus
Now if the 9500i achieves undetectability I would without hesitation give it a try as I feel it may be the best all around detector on the market. It's darn close to the V1's sensitivity without all the falses.
#83
Having owned the V1 for a few weeks I can say I will never go back to any other detector. The arrows alone are so worthwhile and the V1 is always at the top of the list when there are tests on detectors. Once you have the arrows you will never go back, I can't tell you how many times this has helped me particularly at intersections in town.
#84
Originally Posted by ckg35
I 've heard that many ppl go back to their 8500 x50s or even to the V-1 after using the 9500i. There are several reports that the lock-out feature is great as it locks out the false alarms, but has occasionally locked out real police radar! The basic guts of the radar section are supposedly the same as the x50. If you drive 2 x50s side by side, the frequency display in Expert mode may differ a bit between the 2 detectors, so I'm thinking that it's the inaccuracy of the frequency lock that is causing the 9500i to read real police radar as it thinks it's the locked out door opener! At any rate, if this is true, it's not a good thing for 9500i owners.
A detector is only as good as its user, just how a car is limited by its driver.
#85
Just picked up the Passport 9500i yesterday at Best Buy...haven't used it yet, but read the manual thoroughly. Pretty easy to use, but haven't gone thru the programming yet. Looking forward to using it this week on my commute to work.
On a side note, damn, they really guard those high-end radar detectors...they were locked up behind a case. Went in, told the guy which one I wanted, then he had to have his manager come over with a key to unlock it. He asked if I was done shopping and if I wanted to check out there. I wasn't done, so he wouldn't let me take it w/ me to walk around...he had to hold onto it for me and I had to come back for it. Guess they're a hot item to steal!?
#86
#87
on
I have both an X50 and the 9500i. Been using the 9500i for almost a month now and one of the features I really like is the speed display when an alert goes off. So far it has been accurate and saved me well in advance when the coppers are out on the nice days going crazy with their Ka guns. I use the lockout function for false alarms and it seems to work great.
There's always going to be a debate as to which is better, this detector or that detector. Based on the testing I've reviewed, if you get a top tier detector and use it as a tool to help you stay out of trouble and slow down immediately when it goes off, you won't be disappointed with whatever you choose to go with if it keeps you from getting a ticket.
#88
