I think i blew a fuse
Old Apr 24, 2008 | 12:58 PM
JEAThirty5's Avatar
so i have my REM wire for my amp hooked up to an accessory wire behind the dash
i think it shorted, becuase my dash light wont come on and i have no use of any button in the center console, cant turn on/off AC but the clock and stuff on that bar still works, cant turn on radio cig lighter still works, gas light/slip light still works. is there a fuse i can quickly identify or did i fry something in the back? i checked a couple 10A fuses in the front all seemed fine. is there something specific i need to look for? 05 G35 Sedan
TIA
Old Apr 25, 2008 | 10:15 AM
waijai's Avatar
i.love.gold
Check all fuses
Old Apr 25, 2008 | 10:55 AM
Deezflip's Avatar
Originally Posted by Moog
Check all fuses
+1 ..good thing to have is a tester. Sometimes the fuse is bad and you can't tell from a visual inspection.
But always disconnect the battery when working, the whole entire car is the negative part of a battery, you can easily short something out even when your extra careful.
Old Apr 25, 2008 | 12:19 PM
ON's Avatar
ON
^+1 Make sure, make sure, make sure to disconnect the battery when working on electronic parts in your car.
That happened to me recently on a install on a coupe. His center console lights didn't come on a his shifter wouldn't unlock. It turned out to be a 10A fuse by the driver side. Should be labeled "electronic" or "elec". Recheck those again to make sure you didn't miss any.
Old Apr 25, 2008 | 02:18 PM
JEAThirty5's Avatar
i pulled that one saw that it was intact any other way to find out if the fuses are working properly or do i have to pull 1 by 1? and is there another test besides visual that i could do?
is there a fuse on the deck itself? i konw aftermarkets have them
is the AC control connected to the radio? cuz those dont work anymore either
i always pull negative
thanks!
JEAT
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Learned Hand
Oct 1, 2015 09:02 AM
yosip1115
16
Sep 28, 2015 04:14 PM
2014g35x
Sep 11, 2015 07:53 PM
