my avic doesn't like my xbox, but likes ps2, huh??
Old Apr 18, 2004 | 09:37 PM
crashTestDummy's Avatar
for those of you with an avic-n1, have you tried connecting any gaming consoles through the AV input on the brain?
1) xbox (tried two different xbox's) - get a static noise mixed in with the audio, and there are two horizontal bands (that somewhat distort/offset the image) that travel up the screen.
2) ps2 - everything looks fine.
huh? any of you guys run into this? or, can one of you guys try plugging in an xbox to confirm my findings?
DP G35 coupe/ AT / Prem graphite / Sport / Titanium 19 tint / 5 wire hyper-ground kit / clear corners / hyper white clearance/ i-Pod mini silver
San Diego, CA
Old Apr 18, 2004 | 10:19 PM
ikSardarG's Avatar
Re: my avic doesn't like my xbox, but likes ps2, huh??
haha I was just going to post the same observation with the xbox thingie. I actually get static noise through the audio through the AV Electronic tuner. But I think it is more because of the AC inverter than anything else.
When I unplug the power cord from the inverter - everything is perfect.
Anyone know how to stop this static ??? Its in the background of everything playing from the xBox... Can we sheild the units better?
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
2003.5 Desert Platinum Sedan
Premium, Navi, xBox
Old Apr 18, 2004 | 10:54 PM
chisox_23's Avatar
have you guys figured out how to make the dvd feature work while the vehicle is in motion.
i know this is not safe and it is mainly for my front passenger and not me. i have too much fun driving this machine.
thanks
sam
Old Apr 18, 2004 | 11:54 PM
First, I have to say that watching a DVD while driving is just plain stupid, not to mention it's a pretty hefty fine too. I only throw in a DVD when I'm waiting in the huge Costco gas line.
Don't be one of these people ... http://www.ananova.com/news/story/sm_868248.html
Thats said, if memory serves me correctly.... all you have to do is ground the light green wire that's supposed to go to the parking brake. If that doesn't work, then connect the light green wire to the yellow lead wire. ahhh ... it's one or the other. Back to the xbox ps2 thing people!
San Diego, CA
Old Apr 19, 2004 | 12:23 AM
RamboRami's Avatar
G35driver.com Moderator
here is how
http://forum.e46fanatics.com/showthr...7&page=1&pp=20
Basically you connect the unit to the parking brake "ground"... i am not sure what this exactly entails, but I know that most aftermarket units can be "hacked" this way... by a simple ground wire.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Apr 19, 2004 | 01:27 AM
xswl0931's Avatar
Regarding disabling the safety feature, just ground the parking brake sensor (you can hook it up to the black wire which also goes to ground). You shouldn't be watching dvd's or messing with the nav while driving, but it also shouldn't stop your passenger from doing so.
As for static when the power inverter is connected, this is due to a ground loop. Use something like <a href="http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-054">this</a>
Old Apr 19, 2004 | 01:41 AM
supsup's Avatar
where to buy the power line for the xbox or ps2 to the car?
the guy install my N1 did the ground thing for me...
so when i pick up my car..i can watch DVD at anytime!
hey ..also where u guys hide the ps2 or xbox?
what else i need to buy to hook up one of those?
Old Apr 19, 2004 | 02:40 AM
Hmm ... will go to radio shack tomorrow and pick one up. Will let you guys know how it turns out.
supsup - you need to get a DC-AC inverter, something like this http://www.dcacpowerinverter.com/?CMP=KNC-goog13 I picked up a 400w/800w peak with two outlet inverter for around $40 at Costco yesterday. The xbox uses 100watts and ps2 uses 79watts ... blender for margaritas uses 600 watts .... mmm ... too bad, no party in my car ... yet.
San Diego, CA
Old Apr 19, 2004 | 06:31 AM
supsup's Avatar
thax for the info ...
goin to get one when i build my system!
cool!
Old Apr 19, 2004 | 09:33 AM
god_of_cpu's Avatar
StreetDeck.com Developer
Inverters cause a lot of electrical noise when converting from DC to AC. For an X-Box or PS2 your much better off getting a DC-DC converter from radio shack or someplace that will covert the car's 12 volt DC to whatever the X-Box or PS2 needs.
Old Apr 19, 2004 | 11:53 AM
ikSardarG's Avatar
I tried a Ground Loop isolater without luck yesterday. I had one laying around from a previous install...
Amazingly it amplified the noise 10x. Don't know how to handle this now...
Any other suggestions ?
Premium, Navi, xBox
Old Apr 19, 2004 | 01:18 PM
xswl0931's Avatar
Borrow someone else's power inverter to see if at least that will reduce the problem.
Old Apr 19, 2004 | 01:42 PM
flex7825's Avatar
maybe you can try grounding the xbox chassis. it helped a bit with my av box. since the exterior is plastic, this might call for some dremel'ing action.
Old Apr 19, 2004 | 02:02 PM
ikSardarG's Avatar
Well I know that my AV unit is grounded to the chassis...
Has anyone tried grounding the xBox as suggested? I want to be sure of it before I start cutting away... Anyone ??
Premium, Navi, xBox
Old Apr 19, 2004 | 02:22 PM
how does that work, DC-DC converter. Wouldn't that mean that the xbox would have to be modified to remove the internal AC-DC converter to accept the correct voltage from the DC-DC converter. Hmm... that sounds like a whole lot o work to me.
There was a post somewhere saying that the ps2 uses 12 volts, so one installer removed the the ac-dc converter in the ps2 to accept a direct current from the battery. Anyone know anymore about this, or whether it applies to the xbox?
San Diego, CA
