Location of BOSE amp in 05 sedan and questions about sub install
Old Jun 1, 2008 | 09:43 PM
acr's Avatar
acr
I'm getting ready to install a 4080 enclosure and amp in my 2005 G35x. Where is the BOSE amp located in the trunk? I'm also confused about splicing the RCAs. Will any amp accept the signal from the spliced RCAs? some threads i've read talk about a balanced signal, and how only some amps will accept it. I am planning to use the Polk SR104 subwoofer but I haven't chosen an amp yet. Looking for something inexpensive.
Old Jun 2, 2008 | 09:11 AM
jaydafunk's Avatar
the bose amp is located under the rear deck on the driver side. the following is a breakdown of the wires that i recieved from crutchfield.
Bose Amplifier Wiring
1 2 3 4
5 6 7 8
9 10 11 12 13 14 15 16 17 18 19 20
21 22 23 24 25 26 27 28 29 30 31 32
Read number from pin side of vehicle connector. FUNCTION PIN WIRE COLOR
Constant 12 Volt 1 YW
Subwoofer Spkr - 2 BK
Chassis Ground 5 BK
Subwoofer Spkr + 6 WT
*The front door tweeters are wired in parallel with the front door woofers.
The amplifier is located on the underside of the rear deck and is protected by the same constant power fuse as the radio. Read numbers from pin side of vehicle connector. FUNCTION PIN WIRE COLOR
Left Rear Spkr + 13 L.GN
Left Rear Spkr - 14 BK/YW
Right Rear Spkr + 15 OG
Right Rear Spkr - 16 BK/PK
Left Front Spkrs + 17 BU*
Left Front Spkrs - 18 BK/WT*
Right Front Spkrs + 19 BN*
Right Front Spkrs - 20 BK/RD*
Right Rear - Input 23 PK
Right Rear + Input 24 BU
Left Rear - Input 25 YW
Left Rear + Input 26 BN
Right Front - Input 27 RD
Right Front + Input 28 GN
Left Front - Input 29 BK
Left Front + Input 30 WT
Amp Remote 31 GN/WT
Old Jun 2, 2008 | 09:54 AM
acr's Avatar
acr
Thanks a lot. So I would splice in the RCAs to
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Thunderaan
Jul 22, 2015 07:40 PM
