Controlling my Sub Power
Old Jun 11, 2008 | 07:16 PM
ConradoR's Avatar
Hey G35 Enthusiats!
I have an Alpine Type R and an AT8000 Audiobahn Amp that I want to install in my G (bose sound system)
To be able to control my sub power, I was going to get a simple audiobahn sub **** that connects to the amp, but I was at an eletronic e-store that is having some good sales on their Audiobahn stuff.
Would it be worth it to get any of these products instead of just the sub ****?
Would these even do the job of controlling my sub level??
I'm audio retarded, so experts, please help me out... THANKS!!
PRODUCT ONE:
Audiobahn AEQ6Q Factory R/B
Half-DIN Size 5-Band Stereo Equalizer and Line Driver
Five band stereo equalizer (45Hz; 100Hz; 700Hz; 2kHz and 15kHz)
Subwoofer frequencies adjustable 35Hz/250Hz
Active gain preamplifiers with adjustable input sensitivity
Volume gain with up to 8 volts RMS of output
Individual left and right sensitivity controls for DVD input
Low noise BI-FET op-amp design yields minimum distortion
On-Board 30V bi-polar switching power supply
Subwoofer outputs and level controls
Gold plated RCA input connectors
20dB headroom eliminates signal overload
Main/DVD input selector
PRODUCT 2: Audiobahn AEQ7 Factory R/B
Half-DIN Size 4-Band Parametric Equalizer and Pre-Amp
Four band parametric equalizer with 18db boost/cut
Universal half-DIN chassis for ease of installation
90 Days Sonic Electronix Warranty
PRODUCT 3: Audiobahn AEQ8 Factory R/B
Half-DIN Size 4-Band Parametric Equalizer and Crossover
IN-DASH EQUALIZER/PRE-AMP AND CROSSOVER
Independent Adjustable Front and Rear High-pass Cross-over Controls
Subwoofer frequencies adjustable 60Hz/90Hz
Active gain pre-amplifiers with adjustable input sensitivity
Dimensions: 1" (H) x 6 7/8" (W) x 3 13/16" (L)
Would any of these eliminate my need for a power converter to deal with my bose amp?
Thanks
DOMO
Old Jun 11, 2008 | 10:50 PM
Gilley's Avatar
If you connect the sub amp inputs to the rear speaker outputs, you can use the fader to control the sub volume.
Freeman186
Sep 6, 2023 10:07 AM
zcherub
Sep 10, 2015 12:03 PM
yosip1115
Sep 9, 2015 03:30 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
