Air Conditioning issue after Double Din Install
Old May 3, 2016 | 05:16 PM
  #91
guitarrocker98's Avatar
Bump. That piece was not there. Any ideas what happened?
Old Jul 2, 2016 | 11:52 AM
  #92
RewTwin's Avatar
My A/C was working until i installed my DD now the driver side only blows hot air at any temp while the passenger side works just fine. Ive checked everything minus the "jumper" suggestion.
Old Oct 28, 2016 | 09:17 PM
  #93
longboarder81's Avatar
Originally Posted by deadeyes989
FIXED
After messing with the connector, looking for a jumper to remove, and checking the cabin sensor multiple times, I finally found the problem.
A bent pin.
I pulled the main AC connector away from it's respective female port, and one of the pins was bent downward. It's strange though, the pin found just the right spot to slide into so that it didn't obstruct fully inserting the connector. Weird. Either way I'm just so glad it was an easy fix and the JDM AC controller works
Uuuugggghhhhh! Exactly what was wrong with mine!
Old Apr 26, 2021 | 03:27 PM
  #94
Goalie455's Avatar
Infiniti G35 Coupe AMT :(
This thread is so old but I plugged in my sensor and fixed all of my AC issues, thank y'all so much
Old Feb 4, 2024 | 06:58 PM
  #95
Vachel's Avatar
116,404 miles Brembo brakes/slotted rotors Tein coil overs VIS Racing K2 Front Bumper Ch
Originally Posted by docron1
ok...here are pictures that I just took!
this is the in-cabin sensor:
hope this helps!
doc
Do you still happen to have these pictures? Their not available atm but im having the same problem!
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
justgotg35
Jul 19, 2015 12:33 PM
