Double-Din Checklist - Am I missing anything?
Old Jun 27, 2008 | 02:31 PM
RiCeBrNr's Avatar
Hi Folks'
I'll be swaping my Bose w/ NAV stereo for a DD unit. These are the items I plan on purchasing. Can someone let me know if im missing anything?
JDM DD Kit w/ Ac Controller
Scosch Wiring Harness
Antenna Adapter
Pioneer AVIC-F700BT w/ Ipod Cable
For my bose amp to work do I have to purchase anything else?
Old Jun 27, 2008 | 05:40 PM
marcinr's Avatar
20 Year Member
Do you want your steering wheel controls to work? If so, you'll need a steering wheel interface, from PAC, for instance.
Old Jun 27, 2008 | 06:18 PM
trioptimum's Avatar
Yeah, if you wanna use the Bose amp, you need an adapter, and I can't remember the name of it right now... it steps down the volume from the preamp out on the headunit to a volume the Bose amp can use (don't try to hook it all up without this adapter, you might blow the speakers, or at the least it will sound awful). Schosce makes one, but I don't know if they make the best one or not.
Old Jun 27, 2008 | 06:59 PM
RiCeBrNr's Avatar
Thanks!
Can anyone else chime in on a part number or alternative?
Old Jun 27, 2008 | 07:02 PM
JAYY-G35's Avatar
why don't you keep the stock navi and the DD ? like this
Old Jun 27, 2008 | 07:06 PM
RiCeBrNr's Avatar
I think perhaps i'll keep the nav.
You are right about the resale value. Plus it doesn't look to bad, too bad you cant use a custom background on it.
Maybe a NAV2GO module in the future is an option.
Old Jun 27, 2008 | 07:09 PM
JAYY-G35's Avatar
well the only reason i haven't got a double din kit yet, because i can't find it in black.. and i haven't found someone in SD to paint the whole center console Matte black.. but other wise i would go with a DD and the stock navi on top. run the tvandnav2go so i can have 2 screens in function. and it won't look so boring.
Old Jun 27, 2008 | 08:31 PM
Gilley's Avatar
You are referring to an LOC. You don't need one if the HU has RCA outputs, which already output a low level signal that the Bose amp will accept. There is a Metra wire harness adapter kit that has RCA pigtails. You can also cut an RCA cable and make your own.
Old Jun 27, 2008 | 09:05 PM
04G35NYC's Avatar
Metra 70-7551 for Bose AMP to work with aftermarket HU.
Old Jul 2, 2008 | 03:29 PM
White03G's Avatar
With the Metra 70-7551, beside the RCA pigtails, will you just wire 4 other cables (blue, yellow, red, ground)? Is it going to power up the amp? If not, how are you going to do that?
Old Jul 2, 2008 | 05:19 PM
RiCeBrNr's Avatar
I have yet to install or purchase the items so I cant really answer that question just yet
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jeff T
Sep 30, 2015 02:00 PM
markbilo
Sep 30, 2015 01:33 AM
