Door Panel Rattle?
Old Apr 27, 2004 | 04:14 PM
shibal_z's Avatar
Door Panel Rattle?
I sometimes experience a slight rattle/buzz from the plastic door panel near the door lock and window controls at certain bass frequencies. I have the door dynamatted and I have a MB Quart QSD216 midbass driver which creates a s#$tload of midbass that is the source of the rattle/buzz. Wondering if anyone else with aftermarket component speakers have experienced the same and what steps they have taken to eliminate the buzz. I've talked to my installers and they told me that if worse comes to worse, they can reopen the door panels and install foam blocks flush against the panels to eliminate the noise.
<font color=red>Shibal G-Thang</font color=red>
<font color=blue>'04 TB 6MT Graphite: Aero Pkg, Premium</font color=blue>
Old Apr 28, 2004 | 11:38 AM
ctxca's Avatar
Re: Door Panel Rattle?
I have stock speakers but had the same problem. I took it to the dealer and they installed foam padding on all 4 doors. It stopped about 80% of the rattle I was getting.
Old May 6, 2004 | 11:26 AM
1bern's Avatar
I'm all stock and hear a rattle now almost everytime I hit a bump. This is the drivers side door. I'll keep you posted on developments as well as checking to see your progress.
Old May 6, 2004 | 06:28 PM
Catatafish's Avatar
Are you sure it's not your seatbelt hitting the door? Common problem. Also, does it only rattle when the window's open? Also a common problem with frameless doors on coupes.
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 8, 2004 | 09:08 PM
marcg's Avatar
My 04 sedan has a rattle on the passenger's side door panel. It only does this with the stereo on and when almost any base note hits. It stops when the stereo is off or turned way down. I am also experiencing a slight rattle in the instrument cluster area as well. Dealer of course claimed "Could not duplicate". Will have tech. take a ride with me when I go back.
Marc G
Old May 12, 2004 | 02:25 PM
Ratman's Avatar
I have the same problem with the original Bose Speaker. Hey, you take your car to the dealer that you bought the car, or can you take it to any Infinity dealer. ANd they put in the foam pad for free or they charge you.
THanks
Ratman
Old May 12, 2004 | 04:57 PM
shibal_z's Avatar
I got my car in NY which is hundreds of miles from where I live. So I'm going to take it to a local dealer here and see what they can do for me for free. If not, I'll probably take it to my car audio shop and ask them if they can do something for free to fix the buzzing. Anyone who got this take care of at the dealership... was it for free????
Old May 13, 2004 | 01:58 PM
g35mt's Avatar
you should be able to take to any infiniti dealer. the dealer would love it if u take it to them, they get pay for each warranty service from infiniti. can someone confirm and correct if i am wrong.
g35mt
Old May 13, 2004 | 02:53 PM
cato's Avatar
SouthernComfort Moderator
My dealership has worked on my doors on two occasions.
They do it for free under warrenty.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 14, 2004 | 12:45 AM
bamadog's Avatar
Black 2004 G35 6MT, chrome wheels, black, still pristine
Do you have to do this "post-install" or before you put in your door speakers. I imagine that if you put something in there, they'll say they won't fix it because you took it off and probably hosed up something. Hmmmmmm???? Mine doesn't rattle now, but maybe it will later.
The Bamadog
BAMADOG.COM
2004 G35 Coupe - Black/Black 6MT - Chrome 7-Spoke Wheels - Aero Kit & Package w/spoiler - Tint - Alpine System - Body Side Molding
Old May 14, 2004 | 08:27 AM
bebe70024's Avatar
GSQUAD
I also had the same problem, it sounded like a screw was loose or something, so I called the dealership they obviously fixed something because I dont hear it anymore.
Old May 14, 2004 | 10:40 AM
cato's Avatar
My door innards are completely stock, with stock speakers.
So there is no warranty issue.
Old May 8, 2005 | 03:45 AM
Matoumatou's Avatar
I had rattle after 10k. A screw inside door became loose. They retightened and applied lock tight. No problems since.
'03 sedan
Old May 10, 2005 | 11:59 AM
astral_essence's Avatar
since they are aftermarket speakers, it might be the adapters they used to connect to the MB Quart mids. They might have become unfastened and are now rattling against the speaker and the door panel when you hit the bass notes. Make sure that the wiring is zip-tied and taped down so there is no chance of it causing the rattle.
If ater securing this, the rattle continues then it might be a loos screw or some additional foam required as mentioned above.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
itgogitrev
Sep 23, 2015 07:08 PM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
