my battery voltage is below 10 volts :(
Old Apr 28, 2004 | 08:08 PM
Eurog35's Avatar
sigh, i think i found the cause for one of my amps not to go on and my system kinda acting funny, i drained my battery completely a few days ago, and while playing my music pretty loud, my jl 300/4 cuts off, my jl 500/1 was still on... i tried again to see if it would turn on, but the green light stays on for a second and dies right away, the next morning upon startin my car up, it did the same thing, the green light goes on and goes right off, but my other amp stays on...
but anyhow i tried swapping my jl 300/4 amp out to my alpine amp, when i turned it on, the red light was flashing, so i checked my manual to see wut that means, and it says that means my battery voltage is poor and under 10v... so i guess im still in luck with my jl 300/4 amp and that its not damaged, just my battery...
now how do i fix this problem? shouldnt the battery be charged back up by now? sigh please help me someone...
Old Apr 28, 2004 | 09:20 PM
KPierson's Avatar
Re: my battery voltage is below 10 volts :(
If your voltage is under 10 volts most likely your car wouldn't start! Check the voltage AT the amps. If it is below 10 volts check and make sure your ground is solid. If the ground wire came loose your voltage at the amp will drop considerably. Draining the battery down the way you did shouldn't hurt it permanently. To deep cycle a battery you have to completely drain it (leaving a small light, like the dome light on is a good way).
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
Old Apr 28, 2004 | 10:36 PM
Eurog35's Avatar
is there a way i can TEST my amp to see if it gets power? can i connect it directly to the battle to see if the leds go on?
if so, how would i do this? take the remote wire from the amp and touch the positive terminal on the battery?
Old Apr 29, 2004 | 01:51 AM
RocketsRedGlare's Avatar
Go to the store and buy a $5.00 volt meter, not a light, an actual meter. If there is a problem with the wiring for one of your amps, swapping the amps could blow up the other one too. If the battery voltage is 10 volts even after you have started the car and let it run awhile, you have battery/alternator problems. Better yet, take your car to a reputable shop.
On-On
S&S
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
